vtec not engaging in 3rd gear?!?!?! please help
Old Feb 7, 2007 | 06:48 AM
92eg6's Avatar
Default vtec not engaging in 3rd gear?!?!?! please help
Well the problem that I am experiencing is a constant hesitation/ lagging from my car. The vtec engages from 3rd gear on but the RPMs do not rise. For example my vtec is set to 6400 and it will engage up to about 6700 but the rpms will not increase from that point on. Vtec opens fully in 1st & 2nd gear until my rev limit of 9500. But besides this the car is not running as strong as it normally does.
I tried everything i could think of to solve this problem but was not able to find a solution
I changed :
the spark plugs (with the same exact ngk plugs)
the wires
the distributor
swapped out a different chipped ecu & put my chip inside of it
I also checked & cleaned the vtec solenoid.
Checked the oil.
Checked the fuel pressure.
Checked my grounds.
Checked timing.
Old Feb 7, 2007 | 08:04 AM
92eg6's Avatar
Default Re: vtec not engaging in 3rd gear?!?!?! please help (92eg6)
bump...if u need any more information to help me diagnose the problem let me know!! helpppp
Old Feb 7, 2007 | 03:26 PM
Dogginator's Avatar
Daisy... Daisy...
What car?
What ECU?
What CEL?
Old Feb 7, 2007 | 04:52 PM
92eg6's Avatar
Default Re: vtec not engaging in 3rd gear?!?!?! please help (Dogginator)
97 ek...built lsvtec..no cels...chipped p28..tuned by jeff evans using neptune
Old Feb 8, 2007 | 03:29 AM
Dogginator's Avatar
Daisy... Daisy...
The chipped ECU may not register all of the fault codes of a normal VTEC ECU. You need to perform the standard checks:
Oil level
VTEC solenoid screen
Old Feb 8, 2007 | 05:15 AM
Streetz's Avatar
0il level was fine.
Vtec s0len0id was checked & cleaned.
Old Feb 8, 2007 | 09:50 AM
92eg6's Avatar
Default Re: vtec not engaging in 3rd gear?!?!?! please help (Streetz)
werd its streetz car...i was just helping him out....bump
Old Feb 8, 2007 | 06:23 PM
92eg6's Avatar
Old Feb 9, 2007 | 05:58 AM
Streetz's Avatar
0il level was fine.
Old Feb 9, 2007 | 06:06 AM
Dogginator's Avatar
Daisy... Daisy...
Have you verified switching (voltage) from the ECU to the VTEC solenoid? What intake manifold are you running? (GSR head with dual stage intake?)
Old Feb 9, 2007 | 06:34 AM
92eg6's Avatar
b16 w/aebs im
Old Feb 9, 2007 | 06:41 AM
Streetz's Avatar
its a b16 head with aebs manif0ld.
Old Feb 9, 2007 | 06:55 AM
4doorluv's Avatar
b16 w/aebs im
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Streetz &raquo;</TD></TR><TR><TD CLASS="quote">its a b16 head with aebs manif0ld.
are you like his shadow or something?
Old Feb 9, 2007 | 06:56 AM
Dogginator's Avatar
Daisy... Daisy...
Check for the signal at the VTEC solenoid.
Is the bulb for your CEL functional? (It should illuminate when the ignition is in the run position with the engine off.)
Old Feb 9, 2007 | 07:10 AM
92eg6's Avatar
Default Re: vtec not engaging in 3rd gear?!?!?! please help (Initial Dizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Initial Dizzle &raquo;</TD></TR><TR><TD CLASS="quote">
b16 w/aebs im
are you like his shadow or something?</TD></TR></TABLE>
no its actually his car...and im just helping him cause as you can see he dosent really post on h-t much...ill let him do all the answering now that hes a member
Old Feb 9, 2007 | 08:51 AM
Streetz's Avatar
Can y0u Read Initial Dizzle?
92eg Clearly stated that it was my car .
Thank you d0gginat0r but we als0 verified that .
Modified by Streetz at 2:31 PM 2/9/2007
Old Feb 9, 2007 | 09:12 AM
Dogginator's Avatar
Daisy... Daisy...
Did you verify both the CEL bulb functionality and the solenoid signal? Do you have another VTEC solenoid to test? You may be at the point where you need to rig an oil pressure gauge to measure the pressure downstream of the solenoid.
Does your solenoid have the oil pressure switch (USDM, part 15)?
Perhaps you could use the pressure switch to verify oil pressure to the rocker rails during VTEC operation.
Lightsped
26
Jan 8, 2009 02:09 PM
bb_SI
11
Jun 26, 2008 06:13 PM
jc2801
Apr 15, 2008 02:12 PM
slow91crx
Aug 30, 2005 04:43 AM
93civicjaydm
Jul 14, 2005 02:59 PM
