Bad Compression Numbers...
Old Jan 30, 2007 | 05:33 PM
fasil911's Avatar
Default Bad Compression Numbers...
I just randomly did a compression test to see how my engines doing. Here are the results...
All done dry
#1 185
#2 190
#3 185
#4 50
I have a 2000 Civic SI with 135,000 Miles. I did the valve adjustment about a month ago and there are no ticking valves.
Old Jan 30, 2007 | 05:36 PM
s10cky's Avatar
Default Re: Bad Compression Numbers... (fasil911)
was the motor beat on? looks like number one or four took a ****...orrr the valves werent adjusted properly. Do it again.
Old Jan 30, 2007 | 05:39 PM
fasil911's Avatar
Default Re: Bad Compression Numbers... (s10cky)
Would bad valve lashings on one cylinder cause the compression to be that low?
Old Jan 30, 2007 | 06:09 PM
fasil911's Avatar
I just redid #4 with some oil in it. It came up with 55 psi...
89civichb
11
Mar 10, 2009 08:26 AM
acman1
May 21, 2007 12:06 PM
RGoose18
May 21, 2004 10:13 AM
RATEDR
Jun 6, 2002 03:24 PM
LostGsr
Jun 15, 2001 12:29 PM
