Idle speed adjustment on Typer TB?
Hello, does anybody know how to adjust idle speed on the type-r TB? I don't have the type-r suppliment from helms and there isn't a screw under the map sensor like the other b18 TBs that I've seen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devnull »</TD></TR><TR><TD CLASS="quote">A Type-R TB is the same as a GSR. No difference. If you don't have a screw there then you don't have an OE Honda part. And if you got it from Honda you should take it back and have them get you another one.</TD></TR></TABLE>
Are you retarded? You post non-stop about CRAP!
The ITR and GSR TBs are different.
You're right they are different by a few things, mainly having a larger bore. Otherwise they are quite similar. It more likely resembles a OBD-II B16 TB.
post edited
And if you know so much why don't you post on how it is different, rather than attacking me for being over generalized.
post edited
You're right. It does have an idle adjust screw.
What he needs to do is take a picture of it so we can see what he's working with.
My previous statement refers to a few posts today of yours that aren't helpful at all. They're just sassy....
You guys are right, it's there. There was hondabond in the hole that was put in there carefully enough to look like aluminum at first glance. With a flashlight I could see that the color was slightly different so I chipped it out with a screw driver. Thanks for the help
Cleft_Asunder
20
Feb 17, 2009 08:37 AM
SilverWarrior
21
Mar 14, 2008 07:09 PM
BOOSTIN1
Feb 8, 2004 12:53 PM
