vtec problem?
Old Jan 30, 2007 | 08:52 AM
mramerica05's Avatar
Default vtec problem?
I need help, I just bought and put on a new 99 si head for my gsr block. However, there is no vtec. Why?
Old Jan 30, 2007 | 11:17 AM
gibsanez's Avatar
Default Re: vtec problem? (mramerica05)
Any check engine lights? Plug everything back in?
Old Jan 30, 2007 | 11:53 AM
Default Re: vtec problem? (gibsanez)
yes, it reads o2 senor and somethings about coolant senor. But I checked all the plugs and rewired the wires and it still has this problem. I event change my thermostats for my heating. also there is no oil or coolant leak.
Old Jan 30, 2007 | 06:00 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/zerothread?id=1812135
Old Jan 31, 2007 | 04:30 AM
gibsanez's Avatar
Well, every consider you may have a bad o2 senser?
Old Jan 31, 2007 | 06:33 AM
not yet, do i have to replace it? I''ll check on it. However I'm using a obd1 ecu, so only one o2 sensor, the one by the headers should be pulged in right?
Old Feb 13, 2007 | 07:37 AM
OK. NO vtec, I thinK I'll have to take it apart and try to redo everything.
Old Feb 13, 2007 | 08:25 AM
gibsanez's Avatar
have you tried a different o2 sensor yet?
Old Feb 13, 2007 | 08:37 AM
yes, but I just bought new cams so I'll built the motor now and I will switch the o2 sensor. Thank All for your help.
Old Feb 13, 2007 | 09:42 AM
MR_FIX_IT's Avatar
could be ur temperature sensor
Old Feb 13, 2007 | 04:25 PM
JimBlake's Avatar
Default Re: vtec problem? (Purple_GS-R)
Fix the temperature sensor. VTEC isn't supposed to engage until the engine is warmed up.
Old Feb 14, 2007 | 06:07 AM
Default Re: vtec problem? (JimBlake)
I change my thermostats, but I'll check up on the temperature sensor. Also do I just change the plugs for the temperature sensor?
Old Feb 14, 2007 | 10:00 AM
JimBlake's Avatar
Well, maybe not JUST the plugs. The temperature sensor for the ECU is a 2-wire sensor in the end of the head near the distributor. If the wire or connector is loose or corroded (or broken?) then that's what you have to fix. The Helm repair book has a small chart says what electrical resistance the sensor is SUPPOSED to have at different temperatures. Check with an ohm-meter against that chart (sensor in a bucket of hot water with a thermometer).
Bottom line is, if the computer thinks the engine's NOT warmed up, it won't engage VTEC.
For VTEC to engage, all the following stuff has to be OK:
oil pressure (VTEC oil pressure switch)
coolant temperature (ECT sensor OK & engine warmed up)
road speed (VSS & speedometer OK)
RPM (tachometer working)
throttle (TPS)
Old Feb 14, 2007 | 02:06 PM
thanks for your help i'll check it.
Old Feb 15, 2007 | 07:13 AM
Where is the coolant temperature (ECT sensor) Located?
Old Feb 15, 2007 | 01:29 PM
JimBlake's Avatar
End of the head near the distributor.
VTEC oil pressure switch has a 2-wire plug, this sensor is located on the VTEC spool valve.
ECT sensor has a 2-wire plug, looks similar, but it's screwed into the head.
Sender for the dashboard temperature gauge is nearby, it has a 1-wire connection.
Old Feb 20, 2007 | 07:27 AM
Do I change the plugs or clean the plugs? What do I do?
Old Feb 20, 2007 | 09:34 AM
JimBlake's Avatar
First you figure out what's wrong. If a plug on the wiring harness is actually broken, you replace it. If it's simply dirty, then clean it. Broken wire? fix it. Get it?
If nothing visible, you can check the sensor. You should measure the sensor's resistance & compare against the chart of what the resistance is SUPPOSED to be.
Still no joy? You may have to check continuity of the wiring all the way back to the ECU. Judging from your questions, this may be a job for someone who's more comfortable with electrical troubleshooting.
1clean_ Ej
Jan 30, 2007 06:03 PM
Tom123456
Jul 28, 2006 12:04 AM
DBallz
Jul 2, 2003 06:00 AM
turbotime
Jun 18, 2003 03:19 PM
