diagnostic help
Old Feb 3, 2007 | 11:46 PM
teg_racer's Avatar
Default diagnostic help
i just put the engine back into my car after building the block i have put 100 miles on it and the check engine light comes on it feels weak and powerless also at no matter what rpm im in if i put the pedal all the way down it sounds like the vtec is trying to kick in, i want to check to see what codes im throwing but i cant find the plug... chiltons says its either above the ecu or center console way under the dash i couldn't find it. neither could my mechanic, i need to find that and put a conductor (like a paper clip) in there so i can read the codes... can you help me find it?
Old Feb 4, 2007 | 06:23 AM
mmuller's Avatar
Mad Scientist
Default Re: diagnostic help (teg_racer)
ground the wire on D-4
obd1 right?
jd12586
Nov 13, 2006 01:27 PM
DriveSlowHomie
Oct 29, 2005 07:44 AM
nwarp
Jan 12, 2002 09:41 PM
ZUL8R
Oct 5, 2001 06:09 PM
