Retune for different state? necessary?
Old Jan 29, 2007 | 12:10 PM
LSEGHATCH's Avatar
Default Retune for different state? necessary?
I recently purhcased an sc300 from FL and was told to retune in WI to make up for climate differances. I don't see how that would effect anything. I will only be driving the car spring/summer/fall in temps around 50 at the lowest. Any input?
Old Jan 29, 2007 | 05:01 PM
NJIN BUILDR's Avatar
Default Re: Retune for different state? necessary? (LSEGHATCH)
Altitude...Florida is about 1 foot above sea level.Humidity is probably a little different in the summer.
Old Jan 29, 2007 | 05:10 PM
LSEGHATCH's Avatar
Default Re: Retune for different state? necessary? (NJIN BUILDR)
So when the car is dropped off I won't be able to take it for a spin?
Old Jan 29, 2007 | 05:26 PM
If it is setup closed loop it should drive ok.If you experience drivability issues a new tune will most likely take care of them.
Old Jan 29, 2007 | 05:35 PM
LSEGHATCH's Avatar
Closed loop is a new term for me could you please define it? I am more worried about engine failure damage, is that would I will experience or will it just run like ****?
Old Jan 29, 2007 | 06:26 PM
You can set up hondata and most other systems to run closed loop (using o2 feedback for corrections) or open loop which only uses the map to make adjustments.You shouldn't do any damage to the car by not retuning it.But use your good judgment.If it's idling poorly or hesitating get it tuned.
Old Jan 29, 2007 | 06:33 PM
LSEGHATCH's Avatar
Thanks NJIN BUILDR, you calmed my nerves. I wasn't wanting to have to recieve the car, push it into the garage, and then trailer it to get a retune in the spring. I will be going with a better management system in the spring but I would like to drive it before that.
Old Jan 31, 2007 | 06:45 PM
LSEGHATCH's Avatar
Anymore input?
Old Feb 2, 2007 | 08:51 AM
LSEGHATCH's Avatar
One more bump.
kraquepype
Engine Management and Tuning
Nov 16, 2018 09:30 PM
honda_fan06
Oct 28, 2010 09:30 PM
turbob18si
Feb 23, 2009 02:00 PM
JFG Kevin
Oct 13, 2007 12:31 PM
DBallz
Apr 29, 2004 11:39 AM
