Rocker Arm Scoring??
Old Feb 7, 2007 | 08:40 PM
Euro2JDM's Avatar
Default Rocker Arm Help PLS!!!
I'm getting ready to drop in my new skunk2 cams and as i'm taking the valve cover off I notice some scoring on the lobe of the cam. Well as i get further into it I see that the rocker arm has some scoring on it also. You can actually feel it on the cams and a little bit on the rocher arm. Can anyone tell me what caused that and what I should do now??? Please respond soon I'm in process waiting on a green or red light to continue new cam installation. Thanks!!!!
Modified by Euro2JDM at 10:05 PM 2/7/2007
Old Feb 8, 2007 | 03:34 AM
Euro2JDM's Avatar
Default Re: Rocker Arm Help PLS!!! (Euro2JDM)
come on nobody knows anything????????? I thought I could turn to you guys for answers
Old Feb 8, 2007 | 07:17 AM
92redhatch's Avatar
1)did your oil pump ever break? that happens when there isnt enough oil to the head. 2)Or maybe you put the cam caps on wrong and the oil wasnt flowing right.3) Or maybe it has a ton of miles on it and its normal wear.
most likely 1 or 2
Old Feb 9, 2007 | 06:47 PM
PHDZINE's Avatar
IF you have aftermarket valve springs, your seat pressue might be to high...causing way to much pressure on the rocker when the cams open up the valve.
If you have stock valve springs, you might of adjusted your valve clearance to tight causing it to over heat and score.
Old Feb 9, 2007 | 06:51 PM
Euro2JDM's Avatar
i do have aftermarket valve springs... how is the seat pressure adjusted?
Old Feb 9, 2007 | 06:53 PM
PHDZINE's Avatar
Default Re: (Euro2JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Euro2JDM &raquo;</TD></TR><TR><TD CLASS="quote">i do have aftermarket valve springs... how is the seat pressure adjusted?</TD></TR></TABLE>
Shims
Old Feb 11, 2007 | 05:17 PM
h22 civic's Avatar
Default Re: (PHDZINE)
not sure if it is a good idea to reuse those scored rockerarms
Old Feb 11, 2007 | 07:42 PM
Euro2JDM's Avatar
i'm guessing it would probably mess up the new cams??
Old Feb 12, 2007 | 11:43 AM
DonF's Avatar
Yes, it will screw up the new cams. Probably standard wear, I see it all the time.
Old Feb 12, 2007 | 12:15 PM
h22 civic's Avatar
Default Re: (DonF)
possibly drop a valve?
Old Feb 12, 2007 | 01:17 PM
DonF's Avatar
Default Re: (h22 civic)
No, just screw-up the cams.
Old Feb 12, 2007 | 02:31 PM
Chiovnidca's Avatar
Default Re: (DonF)
Dont reuse scored or heavily worn rockers. They may chew up your new cam.
skill178
Feb 11, 2013 08:51 AM
nexgen91
Jul 31, 2007 07:08 AM
ham
74
May 19, 2004 10:34 AM
toooslow
Apr 10, 2003 11:41 AM
