Rod and Piston Wrist pin?
Old Nov 8, 2007 | 11:51 AM
D-SOHC 05's Avatar
Default Rod and Piston Wrist pin?
Hey all, I heard from a few people that pre 96, all honda pistons and rods were held together with a wrist pin and "c" clip and when removing them all you had to do was remove the "c" clip and the wrist pin would slide out. Correct?
The reason I am asking is I have a set of Scat H beams and a set of Nippon P29 pistons with new pins, but no "c" clips. With this combination will the pistons and rods have to be assbled in the shop with a press fit or can I DIY this with some "c" clips if indeed the above is the case.
P.S. I searched this, hence the question. Clarification needed.
Thanks,
Ryan
Old Nov 9, 2007 | 03:58 AM
NJIN BUILDR's Avatar
Default Re: Rod and Piston Wrist pin? (D-SOHC 05)
I have never seen a stock Honda car piston/rod that was full floating.They have all been press fit pins.I'm guessing your Scat rods are designed for a floating pin (bronze bushing in pin end) and your pistons don't have a groove for a clip.You need to have a groove machined in the piston of buy pistons that have a groove (any aftermarket forged).
Old Nov 9, 2007 | 02:43 PM
Chiovnidca's Avatar
Default Re: Rod and Piston Wrist pin? (NJIN BUILDR)
All the older ones are press fit. The new r-series are floating
Old Nov 16, 2007 | 05:20 AM
1700anddroping's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">I have never seen a stock Honda car piston/rod that was full floating.They have all been press fit pins.I'm guessing your Scat rods are designed for a floating pin (bronze bushing in pin end) and your pistons don't have a groove for a clip.You need to have a groove machined in the piston of buy pistons that have a groove (any aftermarket forged).</TD></TR></TABLE>
you my friend don't have a clue as to what you are talking about.that's right
your guessing an after market rod is free FLOAT.why wouldn't be do you really
think they would want you to heat the dam rod up after you just paid 3-700 bucks
hell no.
B18aHatch
Apr 7, 2014 07:07 PM
nenetech
Jan 2, 2013 09:01 PM
NegativeXero
Jun 13, 2007 02:44 PM
eg6madness
Apr 20, 2007 05:32 PM
eg6madness
Apr 12, 2007 03:55 AM
