honda crv stalls when cold
Old Nov 3, 2007 | 09:24 AM
lhurba's Avatar
Default honda crv stalls when cold
My Honda CRV(1999) just started stalling when cold. As soon as it warms up, no problem. It runs a little rough lately though. Changed plugs, wires, fuel and air filters, distributer valve(?). Please help?
I should clarify that when the outdoor temperature drops to about 45 degrees and colder, this problem exists. When the outdoor temperature is warm, above about 45 to 50 degrees, there seems to be no problem.
Modified by lhurba at 12:18 PM 11/7/2007
Old Nov 3, 2007 | 05:42 PM
Chiovnidca's Avatar
Default Re: honda crv stalls when cold (lhurba)
Have you checked the valve clearances? Weve seen a few crvs with receding valve seats cause the lash to tighten up.
Old Nov 3, 2007 | 09:14 PM
dtapia's Avatar
Default Re: honda crv stalls when cold (Chiovnidca)
yup and dont forget the dreaded crv burnt valve. has their been any cel ? but like chiovindca said check valve adjustment and go from their if all looks good do a leak down test
Old Nov 6, 2007 | 03:56 PM
iluvkazumi's Avatar
I've got the exact same thing going on. I've done the tune up and still nothing. What could it be?
what is a burnt valve and how do I check for it? Also, how do I check if I need my valves adjusted?
Old Nov 6, 2007 | 05:03 PM
dtapia's Avatar
Default Re: honda crv stalls when cold (iluvkazumi)
you could do a leak down on the affected cylinder .
Old Nov 7, 2007 | 11:24 AM
lhurba's Avatar
Would this still be the way to go with diagnosing?
Old Nov 7, 2007 | 08:56 PM
dtapia's Avatar
yes i would still inspect the valve clearence and do a cylinder leak down
Old Nov 9, 2007 | 05:41 AM
lhurba's Avatar
I just had the valve adjustment done by my mechanic and my CRV runs like a dream now. I gave him all the very helpful info I received from this forum and he did just that, adjusted the valves which were way off, according to him.
A couple of months ago, when I discovered this forum, I came across someone who gave a website to go to that instructs step by step how to adjust the valves.
It is: http://home.earthlink.net/~michaelpkeefe/ and he will show you how.
If you take it to a mechanic, it is not that expensive at all but that is relevant to what you might think expensive is. Certainly worth the money when the alternatives could be a lot worse! Hope this helps!
Old Nov 9, 2007 | 06:14 AM
dtapia's Avatar
glad it all worked out for you and not the worse case item.
Old Nov 11, 2007 | 02:47 PM
iluvkazumi's Avatar
Wow Ihurba, that's great that it worked out for you. If you don't mind, how much was it? Also, did he do the cylinder leak down as well, or just a valve adjustment? Nonetheless, thanks much to dtapia for all of your help and everyone else.
Old Nov 11, 2007 | 02:50 PM
dtapia's Avatar
Default Re: (iluvkazumi)
glad everyone got some help. a valve adjustment should run about 100 bucks or so depends on the place. the dealer would be around 1.0hr plus v/c gasket and gromets.
Old Nov 12, 2007 | 02:45 AM
lhurba's Avatar
To my knowledge, he did not do a leak-down, only an adjustment. It cost $91.00 which is a little under what I was told it should cost (about $100.00) after I checked around. Good luck!
Old Nov 24, 2007 | 08:51 PM
iluvkazumi's Avatar
much thanks. I'll keep you posted.
knaup109
Jul 8, 2017 04:01 PM
phoenix_iii
Mar 28, 2007 10:27 AM
Cyber ITR
Nov 21, 2004 06:26 PM
Anthrax-VX
Apr 21, 2004 11:07 PM
all77otorhead
Feb 18, 2003 08:02 AM
