What MTF for LSD GSR trans?
Old Nov 11, 2007 | 03:17 PM
pythoner's Avatar
Default What MTF for LSD GSR trans?
I have an empty LSD trans that I need to fill so i can drive...So what MTF should I use?
Old Nov 11, 2007 | 03:28 PM
Padawan's Avatar
Darth ModerVader
Default Re: What MTF for LSD GSR trans? (pythoner)
Honda MTF.
Old Nov 11, 2007 | 03:43 PM
pythoner's Avatar
just MTF?
Old Nov 11, 2007 | 03:55 PM
Padawan's Avatar
Darth ModerVader
Default Re: (pythoner)
Yes, Honda MTF from any Honda or Acura dealer is what you want.
Old Nov 11, 2007 | 05:17 PM
Dogginator's Avatar
Daisy... Daisy...
What LSD do you have? If it is a helical LSD (ITR or Quaife), Honda MTF is a good choice. If it is a clutch pack unit, you need to run what the manufacturer recommends.
Old Nov 12, 2007 | 12:06 PM
Mista Bone's Avatar
D Tranny Guru
Newer MTF is not a good choice for older trannys, it's too thin and watery.
Synchromesh.
Old Nov 12, 2007 | 01:13 PM
dmacaalay's Avatar
Default Re: (Mista Bone)
+1 on the synchromesh! i used gm synchromesh on my gsr and it was great..
Old Nov 12, 2007 | 04:44 PM
pythoner's Avatar
my trans is a JDM GSR trans...just got it here in the states and I now have enough honda MTF for 2 changes...its 8.51 a quart
Old Nov 12, 2007 | 04:46 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (dmacaalay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmacaalay &raquo;</TD></TR><TR><TD CLASS="quote">+1 on the synchromesh! i used gm synchromesh on my gsr and it was great..</TD></TR></TABLE>
yeah use that so after 100k of the tranny it goes to ****. f that
HONDA MTF
Old Nov 14, 2007 | 05:11 AM
dmacaalay's Avatar
Default Re: (B16B_coupe)
mine went over 130k and it never took a dump on me. i started puttin it in since 30k...
Old Nov 18, 2007 | 12:58 PM
blackeg's Avatar
im using syncromesh in my gsr trans with obd lsd .
**** i use syncromesh in all my trannys, ever since it fixed a 3rd gear grind for me a few setups ago
Old Nov 18, 2007 | 02:49 PM
E-Money's Avatar
Default Re: (blackeg)
18X,XXX miles on my trans, just changed the fluid, smoother cold shifting.
Honda MTF
Old Nov 18, 2007 | 07:04 PM
blinx9900's Avatar
Default Re: (E-Money)
pennzoil synchromesh for ctr lsd tranny.
Old Nov 19, 2007 | 07:32 AM
IT GUY's Avatar
new Honda MTF
or
Torco MTF
Old Nov 20, 2007 | 07:12 AM
Gearspeed-Performance's Avatar
Default Re: (IT GUY)
Honda MTF...all day
Old Jan 2, 2008 | 09:59 AM
cachehx's Avatar
Is honda MTF synthetic or is it just plain old 10w-30 motor oil with Honda written all over it?
anyone been using Amsoil 10w-30 synthetic in there tranny??
Old Jan 2, 2008 | 12:19 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner &raquo;</TD></TR><TR><TD CLASS="quote">my trans is a JDM GSR trans...just got it here in the states and I now have enough honda MTF for 2 changes...its 8.51 a quart</TD></TR></TABLE>
holy crap, Honda MTF was never that expensive when I used to buy it.
HONDA MTF </TD></TR></TABLE>
right.
I started putting GM Synchromesh Friction Modified in my car at around 150K miles. My car now has 260K on it, with all original engine and tranny internals and it still shifts flawlessly, even this morning when it was 15 degrees outside.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cachehx &raquo;</TD></TR><TR><TD CLASS="quote">Is honda MTF synthetic or is it just plain old 10w-30 motor oil with Honda written all over it?
anyone been using Amsoil 10w-30 synthetic in there tranny??</TD></TR></TABLE>
Do not EVER put synthetic motor oil in your transmission. It is far too slippery for the gear synchros to work properly.
I don't know if Honda MTF is synthetic, but it's not motor oil. It has friction additives for proper synchronizer operation.
I've been hearing pretty good things about Amsoil's Synchromesh, a 5w-30 fluid that they say replaces Honda MTF as well as MTF for several other car makes. I may try that after I use these last 6 quarts of GM Synchromesh Friction Modified, if I still have my car by then.
jdm2teg
Jan 6, 2007 06:06 PM
K-Spec
Mar 14, 2006 08:49 AM
garyc17
Feb 20, 2006 06:13 PM
SilverDc2
Feb 10, 2005 11:45 AM
baxter04
Jan 14, 2004 02:43 AM
