92 civic eg does not start
The car worked great, i took out the motor to install a lsd on the tranny, put everything back, and now the car does not start. it sounds like it is but it does not. The car has spark i check every spark plug wire the the spark plug to see if i had spark, and all of them do. I am getting lots of fuel, into the motor, when i take out the spark plug they smell like gas, so then i though it might be the timming. everything lines up from the cam sprokets the motor is at top dead center, and nothing, it also cranks but does not start. i have the ground connected for the engine harness, i have the tranny cable connected, and the one for the valve cover. I do not have the vechile sensor connected, do to the gear does not line up with the kaaz lsd. i checked all fuses and they are all good, i do not get a engine code either. i am stuck, any help will be great!
92 civic dx
ls/vtec
gt3076r
1 year ago in my DA
92 civic dx
ls/vtec
gt3076r
1 year ago in my DA
did you remove the motor with the harness or disconect everything and then remove ? check the ground wire at the thermostat housing. does the cel stay on or turn off after 5 sec's ?
i took out the harness, since i check my bearings, the ground in the thermostat housing is on and secure. as for the cell you mean the check engine light? is so it does not come on, when i jump the harness i get the check engine light, but no code
Brycen
Jul 26, 2008 03:50 PM
drift2004
Nov 10, 2007 10:22 PM
