cam journal scoring
Old Nov 5, 2007 | 10:13 AM
huge230's Avatar
Default cam journal scoring
I bought a b16 head online and got screwed.
Im pretty sure i know the answear but this head is no longer useable is it?
Its just this oen thts bad for the most part, I think from laying around, not damaged while running.
This blows
Old Nov 5, 2007 | 06:58 PM
NJIN BUILDR's Avatar
Default Re: cam journal scoring (huge230)
A few dings and dents are not going to ruin the head,It does suck but it will still run fine.Some fine wet and dry sandpaper (500 or finer) wrapped around a socket will remove the high spots.As long as the cam will freely turn by hand you will be OK.
Old Nov 5, 2007 | 07:33 PM
huge230's Avatar
Default Re: cam journal scoring (NJIN BUILDR)
ok thank you. You recommend polishing of some sort after sanding? maybe a dremel with polishing wheel?
Old Nov 6, 2007 | 04:11 AM
Flashmn's Avatar
i dont think I'd even sand that much. maybe a bit with 1000-2000grit and then some Rubbing compoung.
Old Nov 6, 2007 | 04:40 AM
huge230's Avatar
Default Re: cam journal scoring (Flashmn)
thanks for the replies
Nickb20v
Engine Machining & Assembly
Nov 21, 2018 08:59 AM
vanny_david
Jan 9, 2010 06:13 AM
blackeg
Dec 30, 2003 11:00 AM
92redgsr
Oct 23, 2003 06:24 PM
