chipped ecu's not datalogging and solid CEL with no codes - How to test?
Old Nov 2, 2007 | 02:46 PM
MOVE OVER's Avatar
Default chipped ecu's not datalogging and solid CEL with no codes - How to test?
I have a couple ecu's around the house and was trying them out the other day.
One is a P28 and the other is a converted P06. They seem to run the programs burned on the chip, however the CEL is on solid and there are not any codes present.
On a Crome base-map, there is a 4k rpm rev limit.
On a Hondata base-map it ran ok, but horrible lag just before VTEC at the factory ITR settings.
Trying out Hondata, the S100 LED blinks as well as the S200. I am not able to connect to the ecu in order to datalog, or retrieve serial # / option information from the blue box.
I have tested every pin on my harness and it is ok (Kenji harness)
Car is 98 USDM ITR.
What could be wrong and how do I go about testing? I could not find any schematics on the P28 or P06 for testing purposes.
Old Nov 4, 2007 | 06:53 PM
MOVE OVER's Avatar
Default Re: chipped ecu's not datalogging and solid CEL with no codes - How to test? (MOVE OVER)
for those who cared enough to read this:
The problem was that the chip was not burned with the correct starting buffer address..... Problem solved.
And My s200 box is bad so I can't connect to datalog. Bummer.
Old Dec 14, 2007 | 09:42 PM
ironcheftony's Avatar
good to know
Old Dec 15, 2007 | 01:43 PM
zccr-xsi's Avatar
what kinda chips are u useing?and what kinda of burner u got?
Old Dec 15, 2007 | 06:04 PM
MOVE OVER's Avatar
Default Re: (zccr-xsi)
the sst 512 chips
i have a PP2 burner as well as a TOP853 (usb) which I actually like a lot better now that I got it working.
Old Dec 19, 2007 | 04:42 PM
zccr-xsi's Avatar
pp2 burner who makes that willems?
Old Dec 19, 2007 | 05:03 PM
MOVE OVER's Avatar
Pocket Programmer 2, made by Intronics
Old Dec 19, 2007 | 05:05 PM
MOVE OVER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MOVE OVER &raquo;</TD></TR><TR><TD CLASS="quote">for those who cared enough to read this:
And My s200 box is bad so I can't connect to datalog. Bummer.</TD></TR></TABLE>
And also, the S200 unit was bad and had to be replaced.
Old Dec 20, 2007 | 07:21 AM
Relic1's Avatar
forgetting the 8000-FFFF setting on the burner will get you every time.
the moates burn1 sets this as default for the SST 512.
Old Dec 26, 2007 | 09:47 AM
zccr-xsi's Avatar
Default Re: (MOVE OVER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MOVE OVER &raquo;</TD></TR><TR><TD CLASS="quote">Pocket Programmer 2, made by Intronics</TD></TR></TABLE>
hows that working out for ya?is it user freindly?
Old Dec 26, 2007 | 01:26 PM
MOVE OVER's Avatar
its good, but I don't have a parallel port on my notebook computer, so it stays connected to my desktop.
I would be willing to sell it now that I have gotten used to my other burner (Top853 USB burner).
Old Dec 27, 2007 | 05:25 AM
zccr-xsi's Avatar
i use willems dual bruner,took me like a month to learn to use it and almost throwing it against the wall,but after i got the hang of it it is very easy.
digitaldetox
Engine Management and Tuning
Oct 5, 2010 07:23 PM
92HB_HB
Apr 12, 2010 03:58 PM
