oil and battery light came on ???
Old Oct 12, 2003 | 05:19 PM
dpine's Avatar
Default oil and battery light came on ???
tonight my oil and battery light came on came on for a second tonight. revved out 1st and and second and easly switched into 3rd and my battery and oil light came on for a second and when went off. any one have any ideas the car does have oil in it. the car is obd 0 b18c1 in a crx. any body ever ran in to this problem?
Old Oct 12, 2003 | 05:23 PM
vteczone's Avatar
Default Re: oil and battery light came on ??? (dpine)
its probably warning u that ur alternator is about to go in few days...i never notice which captions went on,but if few captions come on when engine is running,its usualyy the alternator.
Old Oct 12, 2003 | 10:06 PM
mugenracer's Avatar
Default Re: oil and battery light came on ??? (vteczone)
check you oil level it may be low and the surge in 1st and 2nd gear brought on the light.....battery light indicates the alternator is not charging the battery properly.
Old Oct 13, 2003 | 03:49 AM
1bad-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteczone &raquo;</TD></TR><TR><TD CLASS="quote">its probably warning u that ur alternator is about to go in few days...i never notice which captions went on,but if few captions come on when engine is running,its usualyy the alternator.</TD></TR></TABLE> Have your alternator tested. Sounds like it's going bad.
Old Oct 13, 2003 | 03:21 PM
dpine's Avatar
Default Re: oil and battery light came on ??? (mugenracer)
oil level is good. is there any way other than taking the alternator out to test to see if it is bad?
Old Oct 14, 2003 | 04:01 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpine &raquo;</TD></TR><TR><TD CLASS="quote">oil level is good. is there any way other than taking the alternator out to test to see if it is bad?</TD></TR></TABLE>With the engine idling measure the voltage, it should be around 14v or so. Then turn on everything you can - lights, fans, defoggers, stereo - with all that extra load it shouldn't drop much. If it's really good it shouldn't drop at all.
Cambo88zc
Feb 8, 2006 05:04 PM
PatrickGSR94
Jul 1, 2005 11:40 AM
PatrickGSR94
Dec 21, 2004 03:37 AM
PatrickGSR94
Dec 19, 2004 07:02 PM
