Brake Bleeder Screw HELP...need size..
Does anyone know the bleeder screw THREAD size? the lil nipple thing on the actual caliper......
I have vx brakes up front and teg discs in the back....thanks...I can't find ****...lolz
Modified by SlowCivicHmm at 11:20 PM 10/13/2003
From: chillin in that city called queen creek, but homes the atl
its 10 mm on every honda as far as i know but if u are going to use a wrench then use the closed in or a brake bleeding tool because open ended wrenches can strip the bleeder valve
I meant the thread size.....
BTW: teg rear disc are 8mm and civic front are 10mm
But I need the t hread size due to the fact I'll be getting SPEED BLEEDERS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowCivicHmm »</TD></TR><TR><TD CLASS="quote">I meant the thread size.....
But I need the t hread size due to the fact I'll be getting SPEED BLEEDERS</TD></TR></TABLE>...And the Odyssey is 11mm.
Run a 8 X 1.25 bolt in the caliper. If it fits, there you go.
