ITR cams with GSR valves ???
Old Jan 17, 2007 | 04:13 PM
kill y-tee's Avatar
Default ITR cams with GSR valves ???
I have a B18C1 that i am installing ITR cams, ITR valve springs and ITR retainers on. My question is....Is it ok to use my GSR valves so that i do not have to remove my head?
Old Jan 18, 2007 | 07:38 AM
soeurm's Avatar
Default Re: ITR cams with GSR valves ??? (kill y-tee)
Yes, it is ok but don't go over the stock rev limit or else you will have a bent valve.
Old Jan 19, 2007 | 04:44 PM
kill y-tee's Avatar
Default Re: ITR cams with GSR valves ??? (soeurm)
On a 2000 GSR, what is best to use....JDM itr cams or USDM itr cams? And also which year cams will be best? All i plan on doing is SK2 IM and TB with Intake and Header and i need to know what you guys recommend would be the best ITR cam swap for me. Thank you.
Old Jan 19, 2007 | 05:31 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soeurm &raquo;</TD></TR><TR><TD CLASS="quote"> Yes, it is ok but don't go over the stock rev limit or else you will have a bent valve.</TD></TR></TABLE>
Only the ITR intake valves differ from the GSR. The ITR rev limit would be just fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kill y-tee &raquo;</TD></TR><TR><TD CLASS="quote">On a 2000 GSR, what is best to use....JDM itr cams or USDM itr cams? And also which year cams will be best? All i plan on doing is SK2 IM and TB with Intake and Header and i need to know what you guys recommend would be the best ITR cam swap for me. Thank you.</TD></TR></TABLE>
All of the ITR and CTS have the same exhaust cam (p/n 14121-P73-J00). THe first ITRs with the 4-2-1 exhaust manifold used the 14111-P73-J00 intake cam. The 4-1 exhaust manifold JDM ITRs used the 14111-P73-J01 intake cam which is very similar to the CTR intake cam. The 2000-2001 USDM ITR with the 4-2-1 exhaust manifold used the 14111-P73-J01 cam as well. You will need to tune your engine for the cams and manifold.
Old Jan 19, 2007 | 05:43 PM
kill y-tee's Avatar
Default Re: ITR cams with GSR valves ??? (Dogginator)
I know that i will need to tune after the install, but i want to know if one cam is better to use on my setup than another. If i have a 2000 USDM GSR, then is the 00-01 USDM ITR cam the best choice for me? Or will the 97-99 cam work just as well? Im looking for someone who knows what is the best ITR cams to use on my setup.
Old Jan 19, 2007 | 05:50 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kill y-tee &raquo;</TD></TR><TR><TD CLASS="quote">I know that i will need to tune after the install, but i want to know if one cam is better to use on my setup than another. If i have a 2000 USDM GSR, then is the 00-01 USDM ITR cam the best choice for me? Or will the 97-99 cam work just as well? Im looking for someone who knows what is the best ITR cams to use on my setup.</TD></TR></TABLE>
The newer ones (14111-P73-J01) have a slight peak HP advantage. There are no USDM or JDM ITR cams, as they were sold in both places. BTW: there is no 99 USDM ITR.
To answer the last part, it is how you tune it ultimately. If you want greater power, many aftermarket cams exist.
Old Jan 19, 2007 | 06:47 PM
kill y-tee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
The newer ones (14111-P73-J01) have a slight peak HP advantage.</TD></TR></TABLE>
Thanks, That was what i wanted to know.
Old Jan 19, 2007 | 07:08 PM
kill y-tee's Avatar
.</TD></TR></TABLE>
And that is why i was asking about jdm and usdm cams because of the 99 jdm integra
VTECdohcter
28
Dec 4, 2007 06:21 AM
IntegraGuy16
Jan 2, 2006 02:26 PM
GSRintegra_Bob
Oct 16, 2005 02:30 PM
darrinbrewer
Dec 19, 2002 08:23 AM
dLo GSR-stolen-now-WRX
Nov 18, 2002 09:03 PM
