blown head gasket questions, need help
Old Jan 8, 2007 | 05:41 PM
RED DA's Avatar
Default blown head gasket questions, need help
hi i have a 91 integra with a b18a1 motor, i also have a blown head gasket and possibly more . So i have coolant in the spark plugs, over heating, and liquid (probably coolant) spraying out from the blown head. i drove the car when it was over heating, really bad , so i was wondering, if there is anything else i have to worry about besides the head gasket, ie. warped block/head?? i really need help, need to start fixing the car fast.
Old Jan 8, 2007 | 07:48 PM
d16vtecx's Avatar
Default Re: blown head gasket questions, need help (RED DA)
get the head resurfaced and a valve job woulb be good since the head is already off
Old Jan 8, 2007 | 07:49 PM
d16vtecx's Avatar
Default Re: blown head gasket questions, need help (d16vtecx)
oh yeah and have them magnaflux the head to see if its cracked
Old Jan 8, 2007 | 07:59 PM
PrettyLude's Avatar
use a "precision" straight edge and measure the deck of the block for straightness
Old Jan 9, 2007 | 03:13 PM
bart2546's Avatar
Default Re: (PrettyLude)
Deffinitely could be a warped head but you'd want to have a machine shop check for it as previously stated with precesion instruments, it may need resurfaced/shaved down.
Old Jan 11, 2007 | 07:15 AM
RED DA's Avatar
so i should just get the head checked? so there shouldn't be anything wrong with the block then? thank you every one for the replies, good advice.
Old Jan 11, 2007 | 09:37 PM
RED DA's Avatar
do you think my block will be fine?
flozella
Aug 30, 2014 07:20 PM
strike1545
May 24, 2010 10:42 AM
new_climber
12
Jan 13, 2009 09:08 AM
integraman 95
Dec 4, 2007 04:30 AM
john457
Jun 26, 2007 05:48 PM
