AN Fitting Dimensions...anyone?
Old Jan 7, 2007 | 08:16 AM
a1320addict's Avatar
Default AN Fitting Dimensions...anyone?
Having some trouble finding the correct fitting I need, not due to inlet/outlet sizing but actual dimension of the fitting.
Was wondering if anyone had physical dimensions on any of these fittings?
All are -6 on each end.
Old Jan 7, 2007 | 11:40 AM
NJcoupe's Avatar
What exactly are you trying to do?
Old Jan 7, 2007 | 11:53 AM
Default Re: (idriveacoupe.)
Loop the power steering fittings off the rack, the line I had on tore somehow and I want to replace it with something I don't have to second guess. I tried a 180º -6 an to a hose barb, and the diameter of the bend was too wide.
Old Jan 7, 2007 | 12:08 PM
NJcoupe's Avatar
Default Re: (a1320addict)
use a metric to -6AN fitting; and use a braided hose to loop it.
Old Jan 7, 2007 | 05:36 PM
Yea, I have the 14x1.5mm and 16x1.5mm fittings already in the rack, I just need to run a T fitting of some sort to the breather....Really don't want to do anything overkill like run 2 feet of SS line...just need to know the dimensions of the fittings listed above...maybe Earl's supplies the numbers?
Old Jan 8, 2007 | 10:15 AM
NJcoupe's Avatar
contact an earls/russel dealer and see if maybe they can help you with some demensions
Old Jan 8, 2007 | 10:27 AM
rtype11's Avatar
the number following the dash - is the numerator of a fraction with a denominator of 12
-6 is 6/12 or half inch, dash 8 is 8/12 or 2/3 of an inch - dash 12 is 1", was this your question?
Old Jan 8, 2007 | 02:04 PM
ITRnorway's Avatar
Default Re: (rtype11)
1ea M14x1.5 to -6
1ea Aluminum Female Flare Swivel #6
1ea #6 Straight Aluminum Socketless Hose End
1ea #6 180 Degree Aluminum Socketless Hose End
5ft #6 AQP Socketless hose
1ea Union Tee, #6 Flare Ends
Old Jan 8, 2007 | 05:41 PM
Default Re: (ITRnorway)
ITRNorway, same problem I'm having. The 180º sits a little too wide of the fitting off the rack.
Old Jan 9, 2007 | 05:06 AM
ITRnorway's Avatar
well, it is noy offset by much. mine works fine with the little kink on the hose. oil would flow fine trough there
Old Jan 15, 2007 | 03:57 PM
Madness's Avatar
Actually, AN sizing is tube size in 16th's of an inch, not 12th's.
-4 is 1/4 tube
-6 is 3/8
-8 is 1/2
-10 is 5/8
-12 is 3/4
-16 is 1
Old Jan 16, 2007 | 01:53 PM
ITRnorway's Avatar
correct
Old Jan 16, 2007 | 07:24 PM
-Darren-'s Avatar
Default Re: (Madness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Madness &raquo;</TD></TR><TR><TD CLASS="quote">Actually, AN sizing is tube size in 16th's of an inch, not 12th's.
-4 is 1/4 tube
-6 is 3/8
-8 is 1/2
-10 is 5/8
-12 is 3/4
-16 is 1</TD></TR></TABLE>
thats some good info to remember, thanks.
ITS_Dunn
Honda CR-V & Element
Oct 29, 2015 07:54 AM
90Acura
Jul 7, 2013 07:12 PM
Eppo
Jul 1, 2011 09:53 PM
Sungsu
Aug 28, 2009 08:38 AM
Dunc
Jun 18, 2006 09:30 PM
