obd0 LS ecu Chipped to run a vtec b16
Old Jan 13, 2007 | 01:14 PM
allnaturalb16's Avatar
Default obd0 LS ecu Chipped to run a vtec b16
is there any way to send an LS ecu to be chipped with a b16 vtec basemap or even just convert the ls to run vtec?
is anyone selling a obd0 b16 ecu?
Old Jan 13, 2007 | 09:07 PM
Default Re: obd0 LS ecu Chipped to run a vtec b16 (allnaturalb16)
well can anyone at least tell me the ecu code for an obd0 LS and i will continue to search like i have been.
no luck searching yet i just want to know if i can get an LS ecu to support a B16 and run vtec
Old Jan 13, 2007 | 10:06 PM
93turbo16's Avatar
The ecu you want is either a PR3 or PW0 (that is a B16 ecu)
The LS is a PR4.
I would highly recomend upgrading to OBD1 though and running a P28. But if that is not an option, I would suggest getting a PW0 or PR3 and running that.
Old Jan 14, 2007 | 03:54 PM
crxking1's Avatar
You can convert your LS ecu to vtec. Check out this website and they have all the info you need.
http://www.ff-squad.com/ecu/info.htm
Old Jan 14, 2007 | 04:02 PM
93turbo16's Avatar
Default Re: obd0 LS ecu Chipped to run a vtec b16 (AntiguaCrx)
I am pretty sure you don't "convert" an OBD0 ecu. You just assign an output for vtec in turbo edit or whatever you are using.
By far the best way is to get a OBD0 B16 ecu and go from that.
efhatch_311
Nov 4, 2009 05:49 PM
90Rexx
Apr 26, 2009 08:27 PM
91civichatchCrX
Jan 26, 2006 01:30 PM
HondaTeg95
Sep 28, 2005 07:42 PM
88 turbo crx
Mar 13, 2004 08:17 AM
