different throw out bearing for a ys1
Old Jan 13, 2007 | 09:14 PM
allnaturalb16's Avatar
Default different throw out bearing for a ys1
i have a cable ys1 tranny and need a new throw out bearing the old one has a slit notch on each side for the spring clip to fit into......
but where the problem lies is.......i bought a 91 LS throwout bearing and it is a bit different it doesnt have the slit notch it has a hook.
are there two different throw out bearings for a ys1 tranny?
i know there are two different ys1 trannys but wouldnt they use the same throw out bearing? which one should i order now?
Old Jan 13, 2007 | 09:49 PM
FIGARILA's Avatar
Default Re: different throw out bearing for a ys1 (allnaturalb16)
Im rather certain that usdm ys1 tranny's only came in 92-93 integras
Old Jan 14, 2007 | 02:48 PM
Default Re: different throw out bearing for a ys1 (F I G A R I L A)
well are there differences in usdm to jdm or LS to B16
Old Jan 14, 2007 | 03:07 PM
FIGARILA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allnaturalb16 &raquo;</TD></TR><TR><TD CLASS="quote">well are there differences in usdm to jdm or LS to B16</TD></TR></TABLE>
Jdm ys1's are a whole other animal that im not sure about.
so you have 91 integra with a ys1? did it come like that stock?
Old Jan 14, 2007 | 05:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F I G A R I L A &raquo;</TD></TR><TR><TD CLASS="quote">
so you have 91 integra with a ys1? did it come like that stock? </TD></TR></TABLE>
i have a b16A that came with a ys1 but not sure if it is long or short geared(ls or b16) and i have a ys1 in my shed that has a throw out bearing that did not match the throw out that i just purchased from star auto parts for a 91 LS which is what i believed was the right bearing
Old Jan 14, 2007 | 05:42 PM
FIGARILA's Avatar
try a 92 throwout bearing...Star ehh? what part of cali are you from.
Old Jan 14, 2007 | 05:45 PM
FIGARILA's Avatar
90-91 trannys are different then 92-93 trannys....im not sure how your original car came with a ys1.
Old Jan 14, 2007 | 06:29 PM
HondaCivicSiR1's Avatar
use a 92-93 ls or gsr throw bearing or fyi you can use a 94-01 integra hydro throw bearing also
Old Jan 14, 2007 | 06:53 PM
FIGARILA's Avatar
Default Re: different throw out bearing for a ys1 (HondaCivicSiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 &raquo;</TD></TR><TR><TD CLASS="quote">use a 92-93 ls or gsr throw bearing or fyi you can use a 94-01 integra hydro throw bearing also </TD></TR></TABLE>
OHHHH...didn't know that, good info.
Old Jan 15, 2007 | 07:03 AM
yeah im close to hemet, Yuacaipa actually. I will try for a 93 gsr then. (cross my fingers)
Nicaraguense13
Aug 30, 2006 09:41 AM
hybrid1990crx
Feb 20, 2005 05:58 AM
the g2 teg
Sep 27, 2004 01:10 PM
johnzm
Jan 12, 2003 08:50 PM
