pinging/pinking
Old Feb 23, 2007 | 04:34 AM
dragaholic's Avatar
Default pinging/pinking
Hi guys,
Recently I am hearing some pinging coming from my motor. I re-set the ecu, check the plugs and they were burning great(light brown). Then I backed off the timing a little(it was set at 16 degrees spot on) and I am still getting the pinging.
I am hearing it all the time now. On idle with a slight tap of the gas and under load(accelerating away from a stop light).
Now one question. I haven't changed the fuel filter since I've bought the car(aobout 1 year). can that cause the pinging?
Help me out guys ita annoying as hell.
Old Feb 23, 2007 | 04:41 AM
Gustav129's Avatar
Default Re: pinging/pinking (dragaholic)
The pinging is detonation, which is caused by running a little bit lean. Running a higher octane fuel will get rid of the pinging, but that only a band-aid for the symptom. It doesn't fix the problem causing it in the first place.
Old Feb 23, 2007 | 08:13 AM
dragaholic's Avatar
can the old fuel filter be causing a lean situatuion.
Old Feb 23, 2007 | 05:41 PM
Gustav129's Avatar
Default Re: (dragaholic)
Yes it can, or Dirty injectors
Old Mar 16, 2007 | 07:02 AM
dragaholic's Avatar
ok guys changed to filter and the pinging stopped. thanks for the advice.
mitchh29
17
Mar 10, 2013 10:06 AM
capm.stabahoe
Dec 27, 2008 06:17 PM
dragaholic
Feb 23, 2007 11:05 PM
aphex23
13
May 21, 2004 05:24 AM
slowd16z6
14
Apr 11, 2004 05:05 PM
