GSR hatch dyno vid and graph.
Old Feb 25, 2007 | 05:48 AM
Azn Kenny's Avatar
Default GSR hatch dyno vid and graph.
Mods:
-B18C1 - internally stock
-short ram intake
-Skunk2 intake mani
-DC Sports header
-BC Spec II exhaust
Comments welcomed!
Modified by Azn Kenny at 10:40 AM 3/13/2007
Modified by Azn Kenny at 11:06 AM 3/13/2007
Old Feb 25, 2007 | 01:37 PM
soo slow's Avatar
Default Re: GSR hatch dyno vid and graph. (Azn Kenny)
wow, i didnt know these things made that much power. i have the same setup except the apexi n1 exhaust and stock intake manifold. hopefully im making at least 160whp.
Old Feb 25, 2007 | 01:41 PM
Azn Kenny's Avatar
Yeah I believe a stock C1 makes about 150 whp so I got 20 wheel with just bolt ons, I am pleased.
Old Feb 26, 2007 | 08:24 PM
daver's Avatar
is this before and after tuning numbers?
Old Feb 26, 2007 | 08:35 PM
b16nonoy's Avatar
nice numbers...I am hoping to get my car dynoed this thursday....
heres my setup:
Darton Ductile Iron Sleeves bored 84mm
JE pistons 84mm(11.5:1 Compression)
Eagle H-Beam Rods
ACL race main/rods bearings
Head has been ported & polished stage 3(3 angle valve job)
KMS development valves, KMS titanium Retainers, & Dual valve springs
Skunk2 Pro-Series 2+ cams
Skunk2 cam gears
Skunk2 pro series intake manifold
Edelbrock 65mm Throttle body
AEM air intake system
Stock OEM type r ignition system w/ NGK iridium
310cc RC engineering injectors
AEM fuel Rail
AEM fuel pressure regulator & AEM FUEL FILTER
Walbro 342 Fuel Pump
Honda OEM 98 spec Type-R Header straight piped to my exhaust
RS-R Exmag Exhaust
ROTATING ASSEMBLY HAS BEEN FULLY BALANCED
Old Feb 26, 2007 | 10:48 PM
AMS MIKE's Avatar
Default Re: GSR hatch dyno vid and graph. (b16nonoy)
Numbers are deceiving.
Check your runs in SAE correction factor
Old Feb 27, 2007 | 06:50 AM
Azn Kenny's Avatar
SAE:
168whp and 125wht.
Old Feb 27, 2007 | 07:10 AM
AMS MIKE's Avatar
Default Re: (Azn Kenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azn Kenny &raquo;</TD></TR><TR><TD CLASS="quote">SAE:
168whp and 125wht.</TD></TR></TABLE>
nice numbers
Good luck with the car. its a healthy one
Old Feb 27, 2007 | 07:13 AM
Freshazzburu's Avatar
Default Re:
You're going to have to compare that dyno with others that have ran their car on that same dyno (at that same shop). Every dyno is not the same, regardless if it's the same model. Check to see their files of other GSR engines that have dyno'd there, it'll give you a better overall comparison of your car with your mods vs a stock engine. Looks like nice numbers BTW.
Next step would be to flatten out that torque curve to achieve a more linear power delivery; it'll feel like you've lost power, but in reality your car will be slightly faster due to more area under the curve.
Old Feb 27, 2007 | 07:18 AM
Azn Kenny's Avatar
Well the shop is new and I was only the second Honda to ever dyno there haha.
Thanks for the advice tho guys.
Old Feb 27, 2007 | 02:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azn Kenny &raquo;</TD></TR><TR><TD CLASS="quote">Well the shop is new and I was only the second Honda to ever dyno there haha.
Thanks for the advice tho guys.</TD></TR></TABLE>
In that case, try and get a few friends with similar engines to dyno at that shop and compare results with them. That will be the best way to analyze your graph.
Good luck with your build
Old Mar 4, 2007 | 08:53 PM
Azn Kenny's Avatar
Yeah that's the plan, I'll post up updates soon.
Old Mar 7, 2007 | 11:07 AM
B18cFreak's Avatar
I think it looks pritty fresh. the a/f is super flat. no ecu tuning or afc?
Old Mar 7, 2007 | 11:13 AM
Azn Kenny's Avatar
No I'm tuning the afr's with CROME.
Haven't touched ignition timing yet.
Old Mar 18, 2007 | 08:20 AM
DC5Danny's Avatar
Streets closed Pizzagate boy
pretty impressive numbers man.
Old Mar 18, 2007 | 05:20 PM
unuselectus's Avatar
Default Re: (DC4Dan)
man... nice numbers.
Your hatch makes me wanna go get mine retuned and dynoed.
I got a gsr with:
*type r cams w/skunk2 adjustable cam gears
*type r throttle body
*type r intake manifold
*type r pistons
*Password Jdm carbon fiber whale ***** intake
*CompTech header
*custom piping w/ spoon silent exhaust
*street tune w/ chrome
I GOTS to go see what i'd put down now! if I don't sell it first...
V-SPEC 1
25
Jul 19, 2016 10:05 AM
negusjuda
23
May 26, 2012 02:42 PM
MidnightAuto
Dec 24, 2011 05:45 AM
D-Rob
K Series
23
Aug 13, 2009 12:56 PM
gsr_beats_20L_lsvtec
Oct 3, 2007 07:29 AM
