cant downshift...
Old Feb 20, 2007 | 10:42 PM
dartdc97's Avatar
Default cant downshift...
i have an annoying problem. i cannot downshift into 4th. i am pretty sure its not synchros or anything gear related inside the tranny. i had this itr tranny in my last car before it was totaled, and it shifted perfect, no grinds. it does not grind, the problem is it just wont go into 4th when downshifting. i have to double clutch from 5th to 3rd, and from 3rd it goes in to 4th fine. shifting up is no problem either, but i can feel a little more resistance when i upshift into 3rd and 4th also, so i know those gears are the problem. i also know that the shifter being used is different, (used to be dc short throw on old car, now skunk2) and i know the linkage is different( old was 97 dc2 b series, now the linkage is from older 94 dc). this car is older, its a 94 ls. i was wondering what the culprit could be and what i should check before i buy a new shifter, linkage, or bushings. would worn bushings cause a problem like this? could it be the linkage? the whole shifter just has more play in it than i would like. i want it to be tight, so what needs to be changed? any thoughts are appreciated.
speedysohc
May 29, 2007 10:38 AM
dartdc97
Feb 27, 2007 11:21 AM
clemsonteg
Jan 14, 2006 10:20 PM
743 Stunna
Oct 19, 2003 09:58 AM
