Best SOHC cam?
Old Dec 30, 2002 | 12:24 PM
95si's Avatar
Default Best SOHC cam?
whats the best cam for the d16z6? cam and gear if you guys have any prefered setups...
Old Dec 30, 2002 | 12:34 PM
Spade's Avatar
Default Re: Best SOHC cam? (95si)
crower stage 3
Old Dec 30, 2002 | 01:00 PM
337 GTI 1.8t's Avatar
Default Re: Best SOHC cam? (Spade)
Old Dec 31, 2002 | 10:28 AM
V3locity's Avatar
what about the zex stage 2 cam???
Old Dec 31, 2002 | 11:49 AM
Spade's Avatar
Default Re: Best SOHC cam? (illdezignzminime)
I will always be a fan of the crowers for the SOHC. Nothing like starting with a blank.
Old Jan 2, 2003 | 02:16 AM
ExospeedAMcrx's Avatar
Exospeed.com camshafts
D16z6/D16y8 (92-00 Civic EX 1.6L sohc vtec)
street SV DUR@.010 INT 300 EX 270 ------- LIFT INT .400 EX .380
Stg3 VT Dur Int 296 ex 288 ---------- Lift int 440 ex 400
Crower
stage 3 Dur Int 284 exh 260 --------- Lift int 441 ex 457
Crane
Stage 2 #12 dur Int 266 exh 246 ---------- Lift int 443 exh 406
You decide....
Wil
[Modified by exospeedAMcrx, 11:17 AM 1/2/2003]
[Modified by exospeedAMcrx, 11:18 AM 1/2/2003]
Old Jan 2, 2003 | 05:16 AM
eg6ajk's Avatar
I run a Zex cam on my motor, and it was fine, but nothing what I expected. no real difference till about 6000rpm then for the next 1500rpm or so it was only an improvement.
Old Jan 2, 2003 | 06:04 AM
Make.............Part#..........INlift............ ..EXlift.........INdur@50......EXdur@50
Honda.......... stock............ 393.............. 369.............. 208.............. 191
Crower 2T.... 63441T......... 430.............. 428.............. 222.............. 200
Crower 2...... 63442........... 427.............. 432.............. 230.............. 204
Crower 3...... 63443........... 441.............. 457.............. 236.............. 216
Zex 2........... 105300......... 455.............. 430...............220.............. 216
Crane 2........ 252-0012...... 443.............. 406.............. 232.............. 218
Gude................................ 397.............. 375.............. 223.............. 192
[Modified by GTI 1.8t, 3:08 PM 1/2/2003]
Old Jan 2, 2003 | 06:56 AM
Spade's Avatar
Default Re: Best SOHC cam? (GTI 1.8t)
None of these show the amount of overlap that is designed into the cams.
I.E. The Crower turbo cam although has mediocre duration, has great lift and a lack of overlap designed into the cam for forced applications.
N/A is more about the valve overlap. That's why the DOHC's have it so good. You can make adjustments until you see fit.
It's not all about the lift and duration either. Most of these are unstreetable (well to a normal person). For a race application you should consult an engine builder and get the cam that best suits the compression and fuel maps you are running.
If not racing suggest a Zex2 or Crower2.
Not sure about crane but, GUDE is a reground cam (NO NO).
If your going for a cheap cam go with Hondasaver. They are regrinds yes but, at about 60% of the market cost you cannot go wrong.
Old Jan 2, 2003 | 07:13 AM
Naturally!
crower stage 3
Awesome cam, however, w/o porting, it's gains will be minimal.
Nothing tells the overlap story like dyno proof and first hand experience. Lift can help you determine if the cam is indeed compatible with your spring/piston setup, and duration can be indicative of idle quality...
[Modified by GTI 1.8t, 4:19 PM 1/2/2003]
Old Jan 2, 2003 | 07:47 AM
Spade's Avatar
crower stage 3
Agree.
But, what Honda head doesn't need porting....hell that is where most of the power is to be made in these engines.
Old Jan 2, 2003 | 08:17 AM
From experience: the d16 heads are good heads for porting but the d15 heads are actually can be played with more.
I really think the main reason alot of people dont give the D series a chance since they are not familiar with its potential and the products out there.
Luckily, there have been people that actually contacted us and were willing to get a head package from us. results... nothing but pure satisfaction. Who here in H-T actually has D series experience and is a true enthusiast.
We love the D series and thats why we can put down 40+ HP increase on just header, intake, exhuast and our head package. and thats on a low compression block still. What more with our high comp blocks?
Good thing theres guys out there like Spade and other loyal D series fans. the D16a6 is a fun motor. I hope others can see its "power" potential as well as its the "fun" factor of building a D series.
Exospeed Preview.... look out for our D series RAce car that should be ready in the Spring. D powered, All motor, EFI, and licensed to drink alcohol.
Old Jan 2, 2003 | 08:54 AM
Default Re: Best SOHC cam? (exospeedAMcrx)
builthatch, bone, bisimoto and spade come to mind...
[Modified by GTI 1.8t, 5:55 PM 1/2/2003]
Old Jan 2, 2003 | 11:10 AM
eg6ajk's Avatar
with Zex as well as Crower 2 & 3, the problem is that they require high c/r, 9-9.5:1 simply won't cut it...at least 11-12:1 is required to get some good power out of them. otherwise you're wasting time.
when I had the Zex (59300) cam lack of higher c/r meant very little gains overstock.
Old Jan 2, 2003 | 11:31 AM
Default Re: Best SOHC cam? (eg6ajk)
if you are a true D series enthusiast. IM me. got some great news I want to share but cannot post for general public yet. its for the good of the D fanatics hehe
Wil
Old Jan 2, 2003 | 11:49 AM
Speaking of regrinds, Crower regrinds sohc cams for $80 and some change. They are limited spec, but so is any other regrind...
[Modified by GTI 1.8t, 8:50 PM 1/2/2003]
Simple SOHC
24
Dec 1, 2005 05:09 PM
BoostinEJ1
52
May 3, 2005 11:16 PM
ScrapinSi
Feb 26, 2003 02:22 PM
USDMMARK
Dec 26, 2002 03:01 AM
Lookincrazy
May 8, 2002 10:25 AM
