can't get nut off of steering tie rod
Old Dec 27, 2002 | 06:26 PM
Lei Siew Long's Avatar
Default can't get nut off of steering tie rod
the nut spins with the thread on the tie rod. what can i do to get the nut off and if the threads are damaged, would i have to replace the tie rod?
thanks in advance
Old Dec 27, 2002 | 06:31 PM
tominos's Avatar
Default Re: can't get nut off of steering tie rod (boostedeg6)
yea, u need a new tie rod.
Old Dec 27, 2002 | 07:05 PM
Default Re: can't get nut off of steering tie rod (tominos)
can i just replace the tie rod only without having to replace the entire rack and pinion steering?
Old Dec 27, 2002 | 09:08 PM
tominos's Avatar
im pretty sure you can replace a tie rod seperately, that would really be a hassle if you had to do the whole thing.
Old Dec 27, 2002 | 09:31 PM
McFly's Avatar
Soak the nut with some penetrating oil and then try it. If that doesn't work then heat it with a torch and try. If all else fails, then get a new inner tie rod. Also get a new retainer lock washer and boot band if replacing the inner tie rod.
Old Dec 27, 2002 | 10:49 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
u dont need to replace it if the whole unit spins, heres what u do, it may work, it may not, i hope u have air tools cause it will make it hella easy...When attempting to remove the nut, take vice grips or anything that u can apply pressure with and clamp it down on the top of the ball joint of the bolt, and the bolt should stop spinning... if u cant fit or find soemthign to clamp down, take the handle end of a screw driver and just PRESS real hard down on the top of the ball joint, and then try to loosen it, its ghetto, but works..
Old Dec 29, 2002 | 12:54 PM
Default Re: can't get nut off of steering tie rod (SIXTYdashONE)
thanks guys but, i eventually got the nut off with an impact gun by tightening and loosening it, over and over again 'til it came off. and i replaced just the tie rod itself.
TOO MUCH TORQUE
Dec 27, 2010 09:16 PM
LOC714
Nov 14, 2009 11:30 PM
96 GSR-T
Nov 22, 2008 05:58 PM
Charri
Oct 18, 2007 03:28 AM
yoffer
Apr 29, 2007 08:33 PM
