HELP ME WITH MY B2O VTEC
Old Oct 5, 2009 | 07:41 PM
jdmluigi856's Avatar
From: lived in south jerz but for now in san juan pr
Default HELP ME WITH MY B2O VTEC
Ihave a b20vtec with a 1.7 gsr head itr valvetrain skunk2 intake manifold bbk throttlebody stock injectors, stock fuelrail, b16 dizzy .dcsport headers n an autozone intake and a p72 ecu
question is vtec enganges once in a while if i turn off da car n turn it back on vtec engages again what could be this problem please help????
B20B
1.7 Gsr Head
ITR Valve springs
Itr Cams
Golden Eagle ls/vtec
Skunk2 Intake Manifold
BBk 68mm Throttle Body
Dc Sport headers
2.5 intake
Apexi WS2 catback exhaust
STOCK P72 Gsr Ecu (no tune)
OIL LEVEL IS OK 4.5QTS 10W30(VALVOLINE)
Old Oct 5, 2009 | 07:42 PM
Default Re: HELP ME WITH MY B2O VTEC
TRIED TO CHECK ENGINE LIGHT SRS BLINKS AND MY CHECK ENGINE LIGHT BLINKS MAD TIMES LONG ONES NEW VTEC OIL PRESSURE SWITCH TOO
Old Oct 5, 2009 | 09:47 PM
Wrench_Si's Avatar
In adequate oil pressure and coolant temperature can cause VTEC not to engage. Check your oil pressure, you can also back probe your coolant temperature sensor with a ohm meter to ensure it is working properly.
Old Oct 6, 2009 | 06:14 AM
how do i check my oilpressure
Old Oct 6, 2009 | 07:08 AM
mouab18c1's Avatar
uhh try to get it tuned...running that setup with a stock p72!! not smart at all...your killing your motor
Old Oct 6, 2009 | 07:40 AM
Wrench_Si's Avatar
To check oil pressure you need either an external oil pressure gauge used to monitor the pressure or there is a oil pressure gauge tool that screws into the existing O/P sensor location on the back side of the block.
BTW what code was it giving you?
S_StarGsr
Apr 29, 2017 08:24 AM
Fastrax203
Nov 30, 2009 01:33 PM
jdmluigi856
Oct 5, 2009 07:45 PM
happyabortion
37
Mar 23, 2009 07:43 PM
JusMike
Jan 21, 2009 02:37 PM
