car wont start
Old Oct 16, 2009 | 07:30 PM
xander1100's Avatar
Default car wont start
have a 99 civic that has NEVER had any issues. went to start it today. pput the key in the ignitian, normal lights came on ok. turned it to power on everything, worked fine. turned it to start the motor, and everything just died with a little "clunk" sound. any help would be much appreciated. btw checked the battery, its perfect.
Old Oct 16, 2009 | 07:37 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: car wont start
ok, if everything was fine yesterday, what changed? did it get cold?
if you are cranking and everything ***** the bed, you have a bad battery or a very poor connection at the battery.
have the battery tested to be sure and go from there.
Old Oct 16, 2009 | 09:48 PM
cr8ter's Avatar
make sure battery is good and connections are good...crank it and if it's making a click every time u crank it over then have someone bang on the starter while someone else is holding it in the start position...if it starts or cranks over rewal quick and stops then it is your starter
Old Oct 16, 2009 | 09:50 PM
cr8ter's Avatar
however, u can remove the starter and just jump it with a battery out of the vehicle and if all it does is click or do nothing then that is the problem....
Old Oct 16, 2009 | 09:57 PM
hondatechnics's Avatar
try pop starting it if that works then its prolly the starter. last time something like that happened to me it turned out the be a bad coil in the distributor.
Old Oct 16, 2009 | 10:04 PM
cr8ter's Avatar
i agree...but is it a manual?????
Old Oct 17, 2009 | 02:56 PM
xander1100's Avatar
sorry, its an automatic.
it wasnt making the clicking sound whne i was trynig to start it, everything just went dead and nothing happened.
problem actually resolved itself earlier today, was pushing it off the driveway so the tow truck could take it to the mechanics and i was able to start it while it was moving and in neutral. started just fine 10 more times after that. just incase its a warning sign for something big, what would cause that?
Old Oct 17, 2009 | 05:06 PM
cr8ter's Avatar
the first thing that comes to mind is the electrical portion of the ignition switch
Old Oct 17, 2009 | 11:59 PM
xander1100's Avatar
would doing a rolling start once fix that problem? its been perfect since then.
Old Oct 18, 2009 | 01:44 AM
cr8ter's Avatar
its an automatic.....u can't push start it like a manual
Old Oct 18, 2009 | 01:46 AM
cr8ter's Avatar
trying to help u out but really hard not having the car to run some diag on....sorry trying the best i can....maybe u do have a loose connection somewhere?...
Old Oct 18, 2009 | 10:40 AM
fcm's Avatar
fcm
Old Fart
A complete loss of power when starting a car, [everything is fine when ign. is turned on but all power is lost as soon as you turn ign. to start] is an indication of a connection problem, because you lose all power it must be a main power or ground connection, it is not unusual for this to be an intermittent issue, it will get progressively worse.
I would check, [pull clean and reconnect] all main power and ground connections, if for no other reason then to eliminate them as the problem. 94
Old Oct 18, 2009 | 07:56 PM
xander1100's Avatar
cool thx i'll hae to try that
inaety
Jun 24, 2011 12:57 AM
jorge59la
Sep 27, 2007 07:24 PM
jorge59la
Sep 16, 2007 06:28 PM
rafiq7
Dec 14, 2004 07:46 AM
See Are X
Mar 6, 2003 10:08 PM
