clutch problem
Old Oct 22, 2009 | 06:45 PM
88 EF Hatch's Avatar
Default clutch problem
I have an 88 dx hatch with jdm b16 and ls cable tranny....Ok so this is hella ****en weird, so my clutch went out a 3 weeks ago, with no signs of slippage or anythings, so when I went to replace it, I came to find out somewthing was really wrong cuz there were chunks of my clutch disc everywhere in ther bell housing, and the side of disc that makes contact with pressure plate was down to metal, there was hella clutch shavings everywhere. So I replaced it with new one 2 wweeks ago and my car ran good, and clutch felt good, today my clutch went out again. Doesn't make sense why, I haven't taken it apart to see if the samething happened, but what could cause this? Clutch cable being too tight? Too loose? Now installing correctly? The transmission? Help please
Old Oct 22, 2009 | 08:59 PM
fcm's Avatar
fcm
Old Fart
Default Re: clutch problem
No way to know without looking.
Is the throwout bearing lever moving freely, all the way to engaged, is cable tight? 94
Old Oct 23, 2009 | 07:29 AM
yes it does, and cable has a bout 5mm of play, but 3 days ago my wheels would want to spin hard to the left on freeway, it was so hard that I could barely hold on to steering wheel. So when I pulled over and just turned wheel to left it was fine. Then today before clutch went out, when I was just driving at like 20 mph, it was doing it worse then ever, I pulled over and messed with it again, and then when I drove at like 65 still doing it real bad that if let go wheels would have turned hard to left, when I started to slow down to come to a stop when I was at like at 3mph I let go of the steering wheel and the steering wheel. Turned a complete 180 degrees. One of my friends said my tranny could be binding, so maybe now differential isn't turning axles and maybe clutch is still good, idk do u think the problem is related?
Old Oct 23, 2009 | 11:03 AM
fcm's Avatar
fcm
Old Fart
Sounds like an axle, [right side] has popped out of the tranny, there may be nothing wrong with the clutch.94
Old Oct 23, 2009 | 11:19 AM
Really? Ok well unfortunately my car is 34 miles from civilization so I'm gonna get it towed to my bros garage and work on it tomorrow
Old Oct 24, 2009 | 04:06 PM
no the axle is still in the tranny
Old Oct 24, 2009 | 07:51 PM
turboacurab20's Avatar
try loosening the cable op to about a inch of play and see if car moves if not then maybe you didnt let the clutch break in proberly 500-1000 miles of easy stop and go driveing?? what brand clutch is the new one maybe u got a lemon / also try moving the car in all the gears maybe u just lost 1st gear
Old Oct 26, 2009 | 10:06 PM
oh damn prolly thats what it is, i didnt break clutch in, cuz after swapping i launched car about 10 times in the 2 weeks, and no none of the gears are working, and im using an autozone clutch, and how much play should my cable have after i change my cluch again?
75euRFE
Jul 11, 2011 10:30 AM
88 EF Hatch
Transmission & Drivetrain
Oct 24, 2009 04:07 PM
88 EF Hatch
18
Oct 24, 2009 04:06 PM
bloodyknuckles
Jun 4, 2004 07:26 PM
