Super Noob Question
Old Oct 6, 2009 | 08:11 PM
gimmethayayo's Avatar
Default Super Noob Question
I tried searching this but couldn't find an answer. Seems like BE is too short of a word to search for. Anyway, my question is, can the BE Bore of a rod be bored to a slightly larger diameter?
Old Oct 8, 2009 | 10:31 AM
Default Re: Super Noob Question
Anyone?
Old Oct 8, 2009 | 01:33 PM
PyroProblem's Avatar
Sure it can. Are you trying to gain some clearance on your rod bearings?
Passtheyayoplease
Old Oct 8, 2009 | 04:00 PM
Yeah. Basically i'm wondering if I can go from a 48mm BE Bore to 51mm BE Bore.
hehe got plenty of yayo to spare
Old Oct 8, 2009 | 04:17 PM
Oh, thats lot of machining. I thought you were just needing another .001" or so...I dont think 3mm is going to affect the overall strength the rod THAT much, but youll probably have to get the bore re-tanged for the bearings. Id consult a good machine shop for your project.
What kinda project you working on if you care to share?
BTW, Id like a quarter pounder,lettuce,cheese,pickles,onion,mustard,ketch up,with extra yayo please
Old Oct 9, 2009 | 08:48 AM
Awhile back there was a guy that successfully created a hybrid stroker kit for the S2000 using oem honda parts. I thought it was awesome, but, the only thing that bothered me was the bad rod/stroke ratio. He said he could overcome this by using something called a block guard, but it still didn't sit well with me.
So after some poking around I think I have something similar, but its all theoretical.
F20c or F22c block
F23a crank
F20b rods
H23 pistons
The only problem I ran into with this was the BE Bore of the f20b rods. They are 48mm compared to 51mm for the other engines (K/H/F).
I do realize that this would be a vary rare project since there aren't many F20B rods lying around (or engines for that matter) and the F23a crank would have to be modified to fit in the F20/22c engine, but its something that i'm still interested in.
Old Oct 9, 2009 | 03:42 PM
Very interesting...Only thing though is a blockguard wont change the r/s ratio. Thats only affected by rod length and stroke, nothing else...
Let us know how it works out. Sounds like a very interesting project...MIght have better luck in the s2k forums....
Old Oct 9, 2009 | 11:18 PM
KWayRacing's Avatar
this may be way off but couldn't you machine the crank rod journals to 48mm?
Old Oct 17, 2009 | 05:27 AM
Could you? I'm a noob when it comes to engine mods.
onlinehost
K Series
Jan 12, 2013 09:13 PM
RattyTuned
Feb 6, 2012 03:08 PM
poch915
Dec 8, 2005 07:40 PM
tegon-gsr
Dec 15, 2004 04:10 PM
