Resistor box on stock motor?
Old Oct 17, 2009 | 04:35 AM
Bigkev616's Avatar
Default Resistor box on stock motor?
I am swapping an ek tomorrow and the motor that was in it before had 1000cc injectors with a resistor box. I was wondering if i could leave the resistor box in and be fine with stock injectors on a stock ls? Thanks
Old Oct 17, 2009 | 05:27 AM
dadrought6's Avatar
Default Re: Resistor box on stock motor?
the resistor box is used with low impendance injectors. in other words, if you checked them on an ohmmeter, they should read 2.5-3.5 ohms of resistamce i believe. high impedance injectors will show a reading of 12.-12.5 or so and they do not require a resistor box. im almost certain all honda obd1 injectors are low impedance.
Old Oct 17, 2009 | 05:41 AM
Bigkev616's Avatar
The motor came out of a 95 ls and im fairly certain there was no resistor box in that car which is why im asking.
Old Oct 17, 2009 | 05:52 AM
GhostAccord's Avatar
A 95 Ls uses high impedance injectors, no need for a resistor box.
Old Oct 17, 2009 | 05:59 AM
Bigkev616's Avatar
So how do i unwire this resistor box?
Old Oct 17, 2009 | 06:11 AM
I'm not sure how you have your box wired in. Here is a wire diagram I made a few months back for wiring up high & low impedance injectors.
Hope this helps.
Cheers
Old Oct 17, 2009 | 06:18 AM
Bigkev616's Avatar
Thanks
ej1serge
Mar 14, 2012 11:33 PM
boosted96teg
Apr 8, 2008 12:15 AM
95dc2teg
Apr 15, 2007 08:32 PM
213374U
Jul 19, 2005 11:55 AM
dc2pffsssttt
Apr 14, 2004 08:04 AM
