idle problems
Old Sep 28, 2009 | 10:34 AM
feriotypeR's Avatar
Default idle problems
i just did a b20vtec swap with a gsr head, i bought a skunk2 intake manifold with a idle air control valve on it and a ls throttle body and when the iacv is pluged up it idles at 2500rpm and when i unplug it, it fluctuates 1000-2000rpm, whats could be the problem? i tried to adjust the screw in the throttle body and clean the iacv, still notin
Old Oct 9, 2009 | 09:03 PM
JDM-h22a's Avatar
Default Re: idle problems
could be vacuum leak somewhere
Old Oct 9, 2009 | 09:55 PM
phazedd's Avatar
hmm... did you change the throttle body gasket?
Old Oct 10, 2009 | 03:58 AM
feriotypeR's Avatar
i dont think i did, my obd2 scanner reads the speed(rpm) fluctuation sensor is bad, could that be the problem?
DO/\/\O
Jul 26, 2011 01:44 AM
ge_ej1
Jan 29, 2008 05:09 PM
NumberB
Jun 7, 2005 02:26 AM
tgh22a
Mar 19, 2005 03:43 PM
bdicustoms
Jun 2, 2003 03:47 AM
