what ecu for my build
Old Oct 5, 2009 | 03:04 PM
hondaman92's Avatar
Default what ecu for my build
i have a 92 civic hatchback with a type r swap the swap is out of a 01 usdm interga i need to find out what ecu to use and if it is needs to be obd1 or obd2
Old Oct 5, 2009 | 03:06 PM
93turbo16's Avatar
Default Re: what ecu for my build
The easiest ecu setup for your car is to get a chipped p28 ecu and get it setup for the ITR.
You could also send out your stock 92 civic ecu to get chipped, converted to vtec, and programed for the ITR, which would be the cheapest way.
Old Oct 5, 2009 | 03:11 PM
hondaman92's Avatar
i was told a p72 ecu but i dont know if it should be obd1 or obd 2
Old Oct 5, 2009 | 03:26 PM
93turbo16's Avatar
The P72 ecu is a GSR ecu.. which is not even close to what should be running the ITR.
For one the ITR does not have IABs, which the gsr has. I would honestly just go with the chipped ecu option.
And the OBD1 or OBD2 choice all depends on what harness you used to put the motor in the car.
Old Oct 5, 2009 | 03:41 PM
Crazy4Honda's Avatar
th vehicle that it is going into is obd1 so why not use a obd1 P72/p28 and chip it? then you can run whatever engine you want with it
Old Oct 5, 2009 | 04:19 PM
hondaman92's Avatar
well i wanted to use a virgin ecu for now in chip it in a couple months do i have that option
Old Oct 5, 2009 | 05:14 PM
mouab18c1's Avatar
no you dont want to run a stock p28 on your itr motor. you could buy a ecu jumper harness converting from obd1 to obd2 since the itr motors are obd2..which would cost more then just getting a p28 chipped with an ITR basemap..
Old Oct 5, 2009 | 06:11 PM
hondaman92's Avatar
i am going to get a p30 ecu jut to start the car up and then chip it in a month
girlsaremean
Nov 6, 2006 06:25 PM
hYbRid_Eg6
Jul 31, 2005 09:36 PM
SSBGSR88
Apr 30, 2004 10:08 PM
fatalman
Dec 22, 2003 06:50 PM
totaled
32
Aug 17, 2003 09:30 AM
