Motor problem
Old Oct 8, 2009 | 09:52 PM
1999ekcoupe's Avatar
Default Motor problem
I have a 1999 honda civic ex with a gsr b18c1 motor swap i have a gsr trans.
Recently it started to act like it had some ***** and run like its supposed to. Its like it pulls like it is supposed to. But then is goes away after a little while. Now its gone and hasn't been like it for a couple months. I have no idea what could cause this... Anyone have a clue??? Thanks
Old Oct 8, 2009 | 10:44 PM
mouab18c1's Avatar
Default Re: Motor problem
you make no sense! what goes away? lack of vtec? specify it more
Old Oct 9, 2009 | 05:20 AM
Its fast one day then the next day it is slow. Its so weird.
Old Oct 9, 2009 | 06:51 AM
mouab18c1's Avatar
what ecu are you running? does it feel like there is a lack of fuel?
Old Oct 9, 2009 | 09:21 AM
P72 I never had time or money to wait and buy a conversion harness so i spliced every wire into the ecu myself. And yeah it does feel like it. I bought a new fuel filter and it is running the same...
Old Oct 9, 2009 | 09:41 AM
mouab18c1's Avatar
since your obd2..the gsr ecu should just plug right in...i dont think you need to splice anything unless your ecu is obd1..which would be pointless to run a stock obd2 motor on an obd1 ecu...
Old Oct 9, 2009 | 07:09 PM
Maybe the motor is an obd1 gsr motor i dunno.
But i need to get a gsr engine harness and see if it plugs in.
Old Oct 12, 2009 | 07:00 AM
mouab18c1's Avatar
does your distributor have one or two plugs?
Old Oct 12, 2009 | 07:40 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
does the needle on your temp gauge come up to the middle (ish) before you start racing around town?
Old Oct 12, 2009 | 09:20 AM
1 or 2? It has 4 4 cylinders. 4 Plug Wires.
My temp never goes above 50% of the way up
Old Oct 12, 2009 | 09:28 AM
jdm inc's Avatar
so you are running and obd1 ecu and you spliced all your wires yourself? i would prob say that is your problem.
Old Oct 12, 2009 | 09:42 AM
Psychoteen101's Avatar
Skipped a tooth on the timing belt possibly?
Old Oct 12, 2009 | 06:49 PM
the motor is an obd2a and my stock motor was a obd2b
Old Oct 12, 2009 | 06:52 PM
I need to find a Honda Mechanic in Maryland
Old Oct 13, 2009 | 06:58 AM
mouab18c1's Avatar
so your saying it runs like a slug now?
Old Oct 13, 2009 | 02:53 PM
Yes it runs like a d motor now
Old Oct 13, 2009 | 09:18 PM
Check your air filter and fuel filter. Seems dumb, but these are two very common areas that if clogged up will cause a noticeable lack in power.
Old Oct 14, 2009 | 07:53 PM
I replaced my fuel filter a couple weeks ago but ill check the air filter
Old Oct 14, 2009 | 08:27 PM
jdm inc's Avatar
sounds like a timing issue like Psychoteen101 said.
jhebbel09
Engine Management and Tuning
Mar 9, 2012 11:09 AM
hndata9600
May 23, 2007 11:07 AM
jvonb
Nov 13, 2005 02:02 PM
gtowni3
Sep 18, 2004 01:37 PM
