Wont turn over...........
Old Oct 17, 2009 | 09:15 AM
B16afmaxt's Avatar
Icon2 Wont turn over...........
So I relocated my battery to the back of my ef. Now when I try to start I'm just get an extremely fast clicking sound. Could it be a ground issue or something ells I am not thinking of. Car started fine before the relocation and I rechecked my wiring severl times.
Old Oct 17, 2009 | 09:29 AM
street_ride14's Avatar
Default Re: Wont turn over...........
Grounding issue. Find a better ground point, check starter as well.
Old Oct 17, 2009 | 10:32 AM
94LS_allmota's Avatar
its the ground wire......also check the starter and make sure all plugs going to it are connected
Old Oct 17, 2009 | 07:01 PM
B16afmaxt's Avatar
Also wondering if it could be lack of cranking amps on the battery. Would that passable have the same result.
Old Oct 17, 2009 | 08:25 PM
fcm's Avatar
fcm
Old Fart
MM&Y of car???
How long is batt. cable?
Where is the cable that runs from the batt., [batt. pos.(+)] to front of car connected?
What gauge is that cable?
What kind of fuse/breaker are you using?
What gauge is the batt. ground?
How long is the batt. ground and where and how is it connected? 94
Old Oct 18, 2009 | 09:42 AM
yeah my buddy had the same problem..try a battery from another larger vehicle and u will notice a difference at the start up
Old Oct 18, 2009 | 06:39 PM
bigredEF9's Avatar
make sure you check your battery terminal connections. some cars wont start because the battery cant get enough amps through a bad connection to start the car.
Old Oct 19, 2009 | 12:38 AM
cr8ter's Avatar
im gonna say battery cables are too long causing higher resistance therefore less voltage to start car
Old Oct 19, 2009 | 07:49 AM
jimbo89's Avatar
Originally Posted by fcm
MM&Y of car???
What gage is the batt. ground?
There could be soo many things wrong... answer these questions for us please. especially where the grounds connected and what gauge cables you are using. Make sure all connections are tight, on starter and battery.
When I relocated the battery in my ef to the back I was able to still start my b18 with the same old battery I had to crank the single cam... You could have a low battery charge though. Check it quick with a multimeter..
Old Oct 19, 2009 | 04:30 PM
KWayRacing's Avatar
FCM has great ?s now we just need answers.
SpecialRequest
15
Jan 2, 2018 09:05 AM
fleschrod
Aug 4, 2015 08:57 PM
tsjeff
Feb 28, 2010 10:43 PM
r b k a
20
Jul 26, 2009 02:40 PM
94PearlWhiteGsr
Oct 15, 2004 07:27 PM
