map sensor swap?
Old Sep 29, 2009 | 08:06 AM
sol of a honda's Avatar
New User
Icon2 map sensor swap?
ok well i have tested and troubleshot most of the problems with idling. members suggest map sensor. now i found a sensor from a 96-97 civic for $74, i have a 93 del sol si 1.6l d16z6. the 93 sensor is $185. would there be a problem if i used the 96-97 sensor in place of the 93. they look identical, i just didn't know if the computer setup would be different and won't read it correctly. has anyone tried this or knows about this if it will work? thanks
Old Sep 29, 2009 | 09:41 AM
mouab18c1's Avatar
Default Re: map sensor swap?
it should work..but try looking for a used one first before spending that amount for a new one and end up not being the problem
Old Sep 29, 2009 | 10:22 AM
TurboChurch's Avatar
junkyard has a million of them and they are all the same if they are on the throttle body. Firewall mounted ones are also all the same. Yours is on the throttle body. They should be less than $20 in every junkyard.
ThatOne02Accord
Apr 25, 2015 12:18 PM
sierrahiker8
Mar 20, 2008 03:25 PM
aznballerz
Jun 12, 2004 12:38 PM
HybridCoupe
Oct 10, 2002 09:20 PM
