Check Engine Light not working
Old Sep 28, 2009 | 01:38 PM
BlownSpeakerBOx's Avatar
New User
Default Check Engine Light not working
the check engine light does not click on when I initially turn on ignition or unplug a sensor. the bulb is good and the green/orange wire has continuity from my cluster to ecu.. any help would be greatly appreciated.. heres my setup
91 civic dx
obd d16a vtec (basically a z6)
p-28 with obd0 to obd1 jumper
stock ignition and fuel system.
Old Sep 29, 2009 | 01:07 AM
j-dmek9's Avatar
Default Re: Check Engine Light not working
91 civic dx
more details please, have u tried a different cluster?? change the bulbs sometimes it reads good but is not working..
Old Sep 29, 2009 | 04:45 AM
srmofo's Avatar
sent pm
Old Oct 15, 2009 | 07:40 PM
New User
yes i have changed the bulb with same result. what details am i missing that could help
Old Oct 16, 2009 | 08:05 AM
hoya_10fintec's Avatar
Not to jack your thread but I'm having the exact same issue here.
D16y8(OBD2b) swap into 97 LX sedan using LX(OBD2a) harness. EVERYTHING is hooked up and working EXCEPT for the engine light. It does not come on at all.
-everything is plugged in
-starter works and cranks over
-checked the cluster with new bulbs and another cluster
-checked all the power/ground connection
-checked all the fuses
-I tried with two different ECU's:: the original ECU and P28 with conversion harness.
-I get no fuel:: because the engine light doesn't come on, the fuel pump doesn't prime.
It's almost as if I didn't plug in the ECU and/or pulled the ECU fuse out. I'm running out of ideas.
anybody else?
Old Oct 16, 2009 | 11:23 AM
New User
nice jack move apprecifate it
Old Oct 16, 2009 | 03:32 PM
fixed the problem... This time, I sanded/cleaned all the surfaces for ground in the engine bay including the main harness ground.
I hope this helps.
Old Feb 23, 2020 | 04:35 PM
Ryan Brill's Avatar
anybody else?
did sanding the grounds work for you also?
THRASH3R
Mar 5, 2018 09:01 PM
91accord25
Sep 22, 2009 07:32 PM
safiy
Mar 18, 2007 07:39 PM
runitup
Sep 11, 2006 06:23 PM
cdakidd03
Dec 3, 2005 09:26 AM
