Used Battery from Junk Yards??
Old Oct 16, 2009 | 06:47 PM
slikz714's Avatar
Default Used Battery from Junk Yards??
i'm just wondering since they sell batteries at the junk yard, are they still good to use? i was short on money and bought one for $20 at the junk yard since the one in my car got tested bad when i brought it to autozone. my car still doesn't start though so i'm not sure if the battery from the junk yard was defective also or there's just another problem to my car ;\
Old Oct 16, 2009 | 06:50 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Used Battery from Junk Yards??
well you really cant tell. you put a suspect battery in the car.
if you can get the car to a shop, do a starter draw test and see if thats it, a voltage drop test.
first make sure all your connections are good.
Old Oct 16, 2009 | 07:09 PM
slikz714's Avatar
my connections are good. its cranking but not turning on. i hear the starter click once or so.. the day before it stopped turning on i heard something sputtering like struggling to turn on. after that it just stopped turning on
Old Oct 16, 2009 | 07:35 PM
Mr. Badwrench
so the engine is cranking, and sounds like it has compression?
if thats the case, you need 4 things for an engine to run
1-air 2-fuel 3-compression and d-correct ignition timing
so go from there.
yeaBuddy
Apr 11, 2011 03:49 AM
trapperj86
Mar 23, 2008 03:05 PM
accordmurf
Apr 24, 2004 04:43 PM
slowboy
Apr 6, 2003 08:41 AM
CivicBoi
11
May 27, 2002 11:30 AM
