motor is in limp mode
Old Sep 29, 2009 | 06:52 AM
delslow!'s Avatar
Default motor is in limp mode
my 01 ls motor has a crank sensor out. but the computer is a pr4. so my question is, is the pr4 obd1? if it is then do i need an obd1 crank sensor? i just wanna make sure before i buy it off ebay. or if one of you guys have one pm me.
Old Sep 29, 2009 | 12:52 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: motor is in limp mode
obd1 cranksensor is in the dizzy
obd2 cranksensor is in the oil pump
what harnnes is the ecu plugged into?
Old Sep 29, 2009 | 10:40 PM
delslow!'s Avatar
damn dude i dont know. i gotta get back to you on that.
if you could post examples of both i will know what to look for
Old Sep 30, 2009 | 05:12 AM
I'm not Rick!
what year car is this in?
Old Sep 30, 2009 | 06:57 AM
delslow!'s Avatar
the motor is a 2001 ls motor but it is in a wagovan. i think it has been ran obd1 though
Old Sep 30, 2009 | 07:14 AM
I'm not Rick!
you need to know what obd your running (ecu and harness)
if its obd1 use an obd1 dizzy and use an obd1 ecu
Old Sep 30, 2009 | 07:54 AM
bayarearacing's Avatar
New User
what is limpp mode?
Old Sep 30, 2009 | 07:59 AM
I'm not Rick!
the ecu goes into SAFE mode and gives you a low rpm and speed limit and stalls out to save the motor from bad damage.
this can happen if you have a odb1 ecu and obd2 dizzy or vice versa
Old Sep 30, 2009 | 08:00 AM
I'm not Rick!
Old Sep 30, 2009 | 08:09 AM
seanbev24's Avatar
pr4 ecu's came in both obd1 and obd0. If it's in a wagovan and is plugged into stock wiring, the ecu is obd0. If there is a jumper harness at the ecu, it's obd1.
Neither ecu looks for a crank sensor, all the sensors are in the dizzy. As long as the dizzy and ecu are the same obd you shouldn't have problems. If it has been converted to obd1 and is also using an obd1 dizzy, the problem could be in the wiring.
Old Sep 30, 2009 | 08:57 AM
delslow!'s Avatar
yea this guy i bought the motor from was talkin about some jumper harnes shat.
Old Sep 30, 2009 | 08:58 AM
I'm not Rick!
thats good. that harness is like $80 with obd1 ecu. your hooked up duder
Old Sep 30, 2009 | 08:59 AM
delslow!'s Avatar
this sucks the motor wont rev past 3 grand
Old Sep 30, 2009 | 09:06 AM
havok hybrid's Avatar
You need to address the wiring issues you have with the distributor and the ecu .
Code 9 is what your getting.. The ecu will not allow the engine to spin at high RPM if it doesn't know where the CRANK is.
You need to Check you ecu codes.. (google how to check honda ecu codes ) if you dont know .
My guess is that you need to fix the wiring at the distributor or the jumper harness is messed up .
the short anwser is your wiring is jacked... Put it all back to OBD 0 .. (stock) wiring.. it will run. But you need a obd 0 distributor
Old Sep 30, 2009 | 09:08 AM
delslow!'s Avatar
im noit sure if he said it had a jumper or if it needed one. if the ecu is obd1 and it is an obd0 harness will it go limp mode without the jumper?
Old Sep 30, 2009 | 09:09 AM
delslow!'s Avatar
ight well if you know someone that has one lemme know, im goin to run it obd0
RageRage
Jun 23, 2014 10:24 AM
streetcartuner
Mar 30, 2008 10:25 AM
killerpenguin21
Jan 7, 2007 06:55 AM
knightnam
Jul 30, 2005 03:07 PM
