how to wire vafc to a non vtec ecu (p75)
Old Oct 3, 2009 | 03:30 AM
civic-one's Avatar
Default how to wire vafc to a non vtec ecu (p75)
Hi does anybody know how to wire a vtec controller to a non vtec ecu can anybody please share the diagram and all thanks in advance
Old Oct 3, 2009 | 03:20 PM
civic-one's Avatar
Default Re: how to wire vafc to a non vtec ecu (p75)
comon no answer.... bump
Old Oct 3, 2009 | 04:00 PM
madking411's Avatar
i had to do this on my car, back before i was running vtec... What you do is make sure first, that you're following the correct ecu pinout supplied by Apex'i. Then, what you do, once you find all the component wires on ur ecu is, find the corresponding wires/colors on the VAFC. There should be 2 for the +12v ignition power(red and orange), 2 for ground(brown and black), 2 for the MAP sensor(yellow and white), 1 for the TPS(grey), and 1 for the tach signal(green) i think. As for the wires that have anything to do with vtec, don't worry about them; just completely ignore them as long as you make sure there's no exposed wires when you're done.
on the ECU, you cut the MAP sensor wire, and run each of the wires through the AFC. That should be the only one you cut. You run the yellow wire on the VAFC into the ecu, and you run the white wire on the vafc to the other end of the MAP sensor wire you just cut. all the other wires, you can just splice the vafc harness wires to them.
Old Oct 3, 2009 | 08:57 PM
civic-one's Avatar
thanks for the info. . . but I want to tirgger vtec using the vafc is that possible of course it is but I dont seem to know how to find the oil pressure on a non vtec ecu does this have a slot for oil pressure and for the vtec solenoid you just wire it up directly to the solenoid itself right.
Old Oct 4, 2009 | 01:25 PM
madking411's Avatar
No, its not possible to "trigger" the vtec with the vafc, all it can do is adjust where in the rpm range you want the low-cam to switch over to the high-cam(not sure on that though, you might want to research it...). It also depends which ecu you have as to whether it has the vtec programmed inside of it.
Drizzo
Nov 26, 2005 09:35 AM
ACrite3404
Feb 14, 2005 05:11 PM
DSSMAX
Aug 13, 2004 08:17 AM
SoldMyEM1
Apr 5, 2004 03:22 PM
Turbo Powa
14
Apr 8, 2003 08:48 AM
