My stick is not stiff enough.
Old Apr 27, 2010 | 09:18 AM
chewyv's Avatar
pm4nudes
Default My stick is not stiff enough.
Alright alright i know the title is iffy but can you all be serious please. It feels like my stick wont stay in place. It goes into gear and stays in gear but feels loose even when its in gear there is just too much wiggle room. I got three different answers. Transmission, shift linkage or shifter bushings. Anyone have this problem or can I find out without jacking the car all the way up to work under it? Its all stock.
Old Apr 27, 2010 | 02:24 PM
mouab18c1's Avatar
Default Re: My stick is not stiff enough.
Its the bushings. You need to jack the car up to replace them. and yes your title did sound a little weird.LOL
Old Apr 27, 2010 | 03:01 PM
Scott_Tucker's Avatar
If it stays stiff for more than 4 hours see a mechanic.
Old Apr 27, 2010 | 04:58 PM
fcm's Avatar
fcm
Old Fart
Ditto both the above^^^^. 94
Old Apr 29, 2010 | 07:38 AM
SuBK's Avatar
ROFL. I'd have that checked out
Old Apr 30, 2010 | 06:46 AM
Matt93eg's Avatar
Do you have the Factory Spring Pin(IE: Bitch pin)in place on the shift linkage or a bolt and nut? If you use a bolt and nut it will give the shifter a lot of "slop". If you have the nut and bolt deal, order a Spring Pin and put that in.
Old Apr 30, 2010 | 06:50 AM
co-cain's Avatar
don't kill me for saying this but it probly is your shift linkage. I know its a pain when you get muiltiple answers but unless some one actully looks at it all any one can do is give their best guess to what it is. And in this case it could be any number of things.
Old Apr 30, 2010 | 06:57 AM
bb6envy's Avatar
sometimes low transmission fluid will cause this. if you can pull it out of gear while driving without the clutch, I would suggest checking your fluid levels and adding some if you need to. its the cheapest solution of the bunch.
Old May 1, 2010 | 05:27 PM
My_Teknique's Avatar
I had the same problem...
Old May 1, 2010 | 06:17 PM
Jaker's Avatar
I think Honda have some little blue pills for this.
Old May 2, 2010 | 12:43 PM
theservant's Avatar
shift linkage and bushings both. a buddy of mine runs hasport linkage with password bushings and its the best, tightest shift ive ever felt. i have a short throw in my coupe but i still would like a tighter shift, so im after some different bushings compared to the oem ones. the bushing that is in the connector to the tranny and the rubber block under the shifter itself will make a world of difference. hope this helps man!
Old May 2, 2010 | 06:10 PM
95DC2GS-R's Avatar
pick up some Energy Suspension bushings and it will solve your problem. I don't think it's the linkage because you would most likely have bigger problems if the linkages were damaged or messed up.
You can get the bushings at Advance/Auto Zone for about 15 bucks and it takes less than 20 minutes to install them.. about 5 minutes if you're mechanically inclined and don't have to fool around with a jack and jack stands
SlowPokeEg
Aug 21, 2011 10:00 AM
rwlangdale
Feb 12, 2008 11:15 AM
chitownrida
Honda Motorcycles
13
May 17, 2005 01:27 AM
tegmech
Jun 14, 2004 10:29 PM
kanzenr91si
Sep 27, 2003 07:26 PM
