Problems with ignition need help!!!! h23a dohc vtec motor
Hey there, so i have a h23a dohc vtec sir motor of a the accord sir and i cant get it to start up. i do have spark and fuel coming thru to the motor. when i crank it, it does crank but it doesn't start. it seems like it wants to start. if anyone has a clue post a reply and would appreciate if anyone help me find out what the problem is... thanks!
Have you checked fuel pressure?
Have you checked timing?
How good is the spark?
Have you checked the cam timing, maybe timing belt has skipped a tooth?
If engine cranks and fuel pressure and spark is good it must be timing.94
EGPHANTOM
19
Jun 3, 2005 11:50 AM
