EGR Fails continuity test!
Old Apr 13, 2010 | 11:34 PM
ketchup's Avatar
Default EGR Fails continuity test!
EGR Connector lift pin 3 (5v) failed the continuity test at ODB1 ECU (P13) connector D19, instead it beeps at D20!
I'm not sure if this is the cause of my Code 12 (EGR) or if it even matters?
If so, should I just remove the pin 3 line from it's current connection found along D20 and split it into D19 somewhere?
This is for the H22 > CRX
The engine harness and ecu adapter was purchased from rywire.
holmesnmanny
Dec 18, 2011 12:51 PM
mywintercar
Sep 25, 2008 07:53 AM
Dingo68
Mar 25, 2007 05:32 PM
vtecn8ive
Jun 22, 2005 08:59 AM
_Endless_
Aug 28, 2002 06:10 PM
