Running at 84ºC 184ºF ECT is bad for engine?
Old Apr 17, 2010 | 04:42 AM
sIrKicK's Avatar
Default Running at 84ºC 184ºF ECT is bad for engine?
Hi, i have two civics, d16z6 turbo and d16z6 na. I installed in both cold thermostats making 85ºC 184ºF at normal working temp instead of 94ºC 201ºF
I installed this thermostats and thermocontacts to run in a lower temp.
Is it bad for the engine? could damage the internals? the temp oscillates between 84 and 95ºC when i driving hard.
Old Apr 17, 2010 | 04:48 AM
D-Rob's Avatar
Default Re: Running at 84ºC 184ºF ECT is bad for engine?
No, that is perfect.
Old Apr 17, 2010 | 05:17 AM
fcm's Avatar
fcm
Old Fart
Ditto that^^^ 94
Old Apr 17, 2010 | 12:24 PM
sIrKicK's Avatar
What is better for the engine, run at 84ºC or 95ºC like stock?
Old Apr 17, 2010 | 07:30 PM
fourthgenhatchB17's Avatar
Either one is fine. I dont run any of the 'cooler' temp stuff. Factory spec for me no matter what the build.
Old Apr 19, 2010 | 09:50 AM
welfarepc's Avatar
IIRC Z1 t-stats are 82c and the rest are 78c.
you sure you got "colder" t-stats not "hotter"?
LL_SP4RROW
Jun 3, 2011 10:00 AM
Boostn B20
34
Oct 19, 2008 10:49 AM
Hanmin
May 29, 2008 03:03 PM
b20integrapower
Jan 1, 2006 09:47 PM
bboylito
Jul 9, 2004 01:51 PM
