Noise When I Shift
Old Apr 17, 2010 | 04:32 PM
Spuds Civic's Avatar
Default Noise When I Shift
You can hear it when you shift from 1st to 2nd and from 2nd to 3rd, only when you push the clutch in and the RPM fall, and im sure you could hear it in the other gears too but your going to fast to hear it, not to sound like a ricer, but it almost sounds like a blow off valve on low boost, like a soft whistle, and im pretty sure you can hear it just a little bit when your in a gear giving it gas, its a hard noise to explain, thanks in advanced
Old Apr 17, 2010 | 07:24 PM
Gabe87CRX's Avatar
Default Re: Noise When I Shift
Hrmmm.... I would check and see if you have some kind of a vacum leak... IDK though..
Old Apr 18, 2010 | 09:22 AM
nismokutz's Avatar
do u know where abouts this sound is coming from?
Old Apr 18, 2010 | 09:44 AM
lil91hatch's Avatar
what car is it?
Old Apr 18, 2010 | 10:02 AM
GagnarTheUnruly's Avatar
My car has an rpm dependent exhaust rattle that sounds just like that. It's only noticeable as the engine drops revs because the sound is hard to hear over the engine if the throttle is open. It happens around 2700 rpm for me. I know mine's an exhaust rattle because it happens independent of clutch position, throttle position, or vehicle speed, but it's very hard to hear over the engine except when the engine revs drop when I put the clutch in.
Old Apr 18, 2010 | 04:25 PM
its a 92 hatch with a b16, keep the info coming
Old Apr 18, 2010 | 06:50 PM
lil91hatch's Avatar
yea sorta sound like it could be a rattle somewhere around the exhaust
Old Apr 18, 2010 | 07:31 PM
Mines a 96 GSR. I'm not saying you've definitely got an exhaust rattle, but your description sounds similar to my situation. Try lightly revving the engine up and listening for the noise.
AVA
17
Apr 7, 2009 03:59 PM
RTW DC2R
Oct 8, 2006 08:10 PM
743power
Jun 2, 2004 05:51 PM
fsck3r
May 25, 2003 11:50 AM
