cleaning valves
Old Apr 28, 2010 | 04:28 PM
that-guy's Avatar
Default cleaning valves
finally going to assemble and put my B18 back in my car this weekend. i was going to glass bead all the carbon off of my valves, but my machine shop is down for about two weeks, so i was wondering how everybody else cleans their valves at home without using glass beads or anything?
Old Apr 28, 2010 | 04:46 PM
NJIN BUILDR's Avatar
Default Re: cleaning valves
Wire wheel will work.Some people prefer it to glass bead.
Old Apr 28, 2010 | 04:51 PM
that-guy's Avatar
that won't damage the valve at all? is there some sort of a solvent that i can maybe soak the valves in for a night or two that will lift majority of the carbon off?
Old Apr 28, 2010 | 04:57 PM
Oven cleaner will work if your not in a hurry.You can't hurt the valves with a typical wire wheel.The stem would be the only part you could hurt,but you should be staying away from the stems with glass bead anyway.Some people slide a piece off rubber line over the stem when they glass bead or wire wheel.
Old Apr 28, 2010 | 05:04 PM
that-guy's Avatar
well i know not to touch the stems, and i have always put rubber tubing over them before blasting, but my shops blaster is down. i guess i'll let them soak in some concentrated purple for a few hours, then try to tooth brush it all off, and maybe bust out the wire wheel
Old Apr 28, 2010 | 05:11 PM
Like I say,many shops use a wire wheel,even when their glass bead cabinet is working.
crazyminis
Dec 6, 2012 08:30 PM
scarney
Aug 22, 2009 09:15 PM
vtecn8ive
Sep 19, 2008 01:23 PM
njracer
Nov 2, 2007 02:36 PM
97grnrs
Sep 30, 2007 05:00 PM
