Engine only revs to 3000rpm
I just recently installed a new (used) motor in my 97 prelude, the car idles fine but wont rev past 3000rpm and seems to be stuck in limp mode. The ecu is throwing a crank position sensor (p0335) but i was wondering if there is any way i could check to see if the CPS is working properly before i pull everything out and buy a new sensor. I really need to get the car back on the road so any help is appreciated.
yea u can get a voltmeter and measure resistance in the sensor, look in the electrical section of this forum for the voltage guide for which sensor should read what...
roy ezechukwu
Feb 6, 2014 02:13 PM
