obd2-obd1 00si missing a/c signal
Old Apr 7, 2010 | 06:14 PM
Bexe's Avatar
Default obd2-obd1 00si missing a/c signal
I have an 00si with an 0bd2-0bd1 jumper harness; I have no a/c signal with the obd1 jumper/ecu's I have tried 3 ecus without any success at getting an a/c signal; thus it is not the ecu's.
When I plug in the 0bd2 ecu I get the a/c function and clutch engages. Has anyone had it before; how can I tell if my jumper harness is 0bd2a vs. 0bd2b? Also would this effect the A/C function? I have looked at the stock wiring diagrams and understand how the ecu actuates the a/c function. I have also searched this via ecu pinouts and understand that the obd1 ecu's use A15 for the A/C clutch relay and I believe it is B05 that actuates it on the obd2 ecu's. If I am wrong please correct me I plan to splice these two if I find that my jumper harness lacks this connection.
Thanks in advance for advice if people answer!
Dave
Old Apr 9, 2010 | 06:51 AM
perseverance's Avatar
Default Re: obd2-obd1 00si missing a/c signal
i've had a similar problem. my ac fan would turn on with the ac but the compressor wouldn't. so i just jumpered the wire from my fan to the ac compressor and it works just fine. compressor still turns on and off with temps like it's supposed to
Old Apr 11, 2010 | 04:11 PM
blown_ss's Avatar
i would like for you to explain how you do this. im having the same problem. thanks.
kywnichoEM1
Jun 7, 2020 05:45 PM
fitseries3
Nov 18, 2019 04:05 PM
frank316
17
Jun 20, 2011 03:44 PM
I Kick Squirrels
Aug 19, 2009 11:52 AM
lude54
Mar 29, 2006 09:46 AM
