Drill holes in window?
Old Apr 26, 2010 | 09:53 AM
S2Integra's Avatar
Default Drill holes in window?
So recently my GSR's back glass shatter into a billion pieces. I have a carbon hatch, and glass is expesive. $1400 from safelite. $700 plus shipping from auto parts websites. So I started looking at FAL's Lexan lightweight windows. They are made of 1/8 polycarbonate. My question is it possible to drill through this material? Is it sort of like pexy glass as opposed to real glass? I thought I saw that it was possible to rivet these windows, but cannot be for sure cause I can't relocate info. I need this for mounting the 3rd brake lamp. I guess I could glue it on, but I'd rather bolt it in.
Old Apr 27, 2010 | 06:47 AM
sleepinonacreeper's Avatar
Default Re: Drill holes in window?
i wouldnt rivet it. rivets could crack the lexan very easy. window weld or screws will work and you can drill it. i also wouldnt mount the third brake light to a fal window. if your carbon hatch has the factory plastic trim inside you can mount the brake light to the bottom trim. also getting a rusted up or damaged hatch for the glass is an option.
Old Apr 27, 2010 | 05:10 PM
fcm's Avatar
fcm
Old Fart
Lexan can be drilled and routered, cut with a hacksaw blade, skill saw or Plexiglass knife,
I also would not rivet it unless preset depth rivets are used.
Lexan is much harder then plexiglass so much more brittle, it is also why it does not scratch as easily as plexiglass does. 94
Old Apr 28, 2010 | 10:32 AM
S2Integra's Avatar
Okay thanks. It does not. I have a 3rd brake lamp that mounts to the window directly, and carbon hatch cannot even accept that rear cowl behind the deck. I just wanted to get something other than glass and still have 3rd brake lamp.
Old Apr 28, 2010 | 05:25 PM
red92si's Avatar
I would buy a cheap universal LED brake-light strip. Should be thin enough to mount anywhere and can be mounted with 3M double-stick.
Old Apr 29, 2010 | 07:33 AM
SuBK's Avatar
Do not Rivet.. thats for sure
shocker911
Paint and Body
Jun 20, 2011 02:07 PM
mikecp
May 31, 2011 07:12 AM
S2Integra
Apr 26, 2010 09:32 AM
DazeMS
Jan 21, 2010 05:29 PM
runghostrun
Oct 14, 2009 07:33 AM
