which bearings to use?l
Old Apr 11, 2010 | 12:35 PM
sh!ft's Avatar
Who the fack changed my title?!
Default which bearings to use?l
I'm putting togeather an ls vtec turbo motor, but using a gsr crank in an ls block with the addition to adapting the gsr block girdle on the bottom end as well. BUT when using the ls main caps, which main bearings do I use since I'm running a gsr crank?
Old Apr 12, 2010 | 02:18 PM
sh!ft's Avatar
Default Re: which bearings to use?l
....23 views and no reply? thought this was honda-tech.....
Old Apr 12, 2010 | 02:38 PM
phunhaus's Avatar
Match the numbers/letters on the block and crank and decipher the Honda color.
Old Apr 12, 2010 | 03:42 PM
sh!ft's Avatar
can i get an actual answer instead of a preschooler answer
Old Apr 12, 2010 | 06:09 PM
kyden's Avatar
all b series main bearings are the same, so it doesnt matter.
don't be such a jerk, you're not gonna get far on here with that attitude.
Old Apr 12, 2010 | 06:24 PM
sh!ft's Avatar
how was i being a jerk? i was being honest. stupid comments will get stupid answers. and no from what I have been told by my machine shop they are NOT all the same
Old Apr 12, 2010 | 07:34 PM
kyden's Avatar
you just proved my point. i gave my answer (which is correct btw) and you refused to believe it.
theres no difference between a green gsr main bearing and a green ls main bearing. its the same part #.
Old Apr 13, 2010 | 11:12 AM
Trey's Avatar
25 Year Member
This is the correct answer.
The block and crank have stamping on it which correspond to the honda color bearing. You could always just use Green all the way across like the ACL bearings do.
Old Apr 13, 2010 | 09:38 PM
sh!ft's Avatar
like i know any of this ****. im really missing the point with the "color" thing
Old Apr 14, 2010 | 04:20 AM
kyden's Avatar
get a helms manual.
jsalter@butte
Engine Machining & Assembly
Aug 20, 2016 03:50 PM
POORMANT
Jan 29, 2009 05:15 AM
boostd ls
Mar 6, 2008 02:02 PM
drift2004
Nov 21, 2005 03:54 PM
migs
10
Jul 15, 2005 07:40 PM
