painting valve cover.
Old Apr 22, 2010 | 04:46 AM
EF9_TryMe's Avatar
Default painting valve cover.
Im thinking about painting my b16 valve cover and was wondering what I should use to remove the paint, I heard aircraft works good .. and it's cheaper than sand blasting.
The other thing I also wanted to know once you remove the old crap off the valve cover, do you just spray paint the letters black, cover it up once its dry with masking tape, and then spray over the valve cover whatever color you want ?
Old Apr 22, 2010 | 05:28 AM
perseverance's Avatar
Default Re: painting valve cover.
aircraft remover works great, don't use the home depot stuff it's really weak. get some from an autozone, advanced, pepboys, etc. as far as the letters go, everyone has their own way of doing it. try your way and see how it goes. i typically shave the letters back to metal after painting that way it looks somewhat factory.
Old Apr 22, 2010 | 07:34 AM
GagnarTheUnruly's Avatar
Aircraft remover works well. You'll need to use about a can of it, and then you use a paper towels to remove the congealed paint and a wire brush and sandpaper to get off the stubborn paint. Then you need to polish the head a bit with sandpaper in order to get a good finish. If you don't get a nice smooth finish the paint will look crappy.
Old Apr 23, 2010 | 07:24 AM
EF9_TryMe's Avatar
you mean polish the valve cover ?
Old Apr 23, 2010 | 07:25 AM
8VEYBEYB's Avatar
no he means sand it.
Old Apr 23, 2010 | 07:53 AM
HoNda PriNcess's Avatar
i hope you have lots of simple green on hand. when i did mine, i had to soak it for hours in that crap and just keep scrubbing it with a toothbrush.
Old Apr 24, 2010 | 04:21 AM
EF9_TryMe's Avatar
gotcha, thanks guys for the tips.
SeanK325
44
Dec 14, 2010 09:37 AM
pjr710
Paint and Body
Aug 10, 2007 07:24 PM
4twenty_CRX
32
Jul 17, 2007 09:34 PM
Dancing is Forbidden
11
Jun 24, 2003 05:43 AM
ih8danoles
Oct 27, 2002 01:22 PM
